READ TOGETHER WITH LATER UPDATES
Here is my take on Fluke's chopper replacement board.
So it doesn't get lost, I'll start with my biggest doubt.
In an original-construction instrument using neons, when T202 terminal 9 goes positive, DS101 lights, turning on V101. (When it goes negative DS102 lights turning on V102.)
But in an upgraded instrument with Fluke's H11F1 board, when terminal 9 goes positive, I calculate that U5, the H11F1 replacing V101, turns OFF instead of on.
How can this be? The meter would read downscale for positive input and vice versa. Did they modify other places? Why not just make the H11F1 board do the right thing?
It makes my head spin.
Here is my writeup, attached and inline. It refers to posts by TiN, Jay_Diddy_B, and picburner, especially post #7 and #14, which for me show up on page 1 of this thread.
For easy reference, I also attach pictures and schematics from the above posts.
I'm looking forward to your analysis and comments.
Thanks,
Dave Wise
FLUKE 845A CHOPPER REPLACEMENT BOARD
David Wise
September 2019
The Fluke 845A, 845AB, and 845AR Null Detector was designed with
a photocell chopper. But see the NOTE in the Change/Errata pages
of 845A_AB_imeng0000.pdf . (This is pdf page 3.) Transcribed below.
See
https://https://xdevs.com/fix/f845ab/See
https://www.eevblog.com/forum/metrology/teardown-fluke-845aabar-tweaks-and-mods-(and-repairs)Photos at
https://doc.xdevs.com/doc/Fluke/845AB/img/f845_chopt.jpg and
https://www.eevblog.com/forum/metrology/teardown-fluke-845aabar-tweaks-and-mods-(and-repairs)/reply #7 March 3 2016 by Jay_Diddy_B, attachment "green board.jpg" .
NOTE
A major circuit modification has been made to the Fluke
Model 845AB. This change entails the complete redesign
of the Photo Modulator, previously based on
photo-conductive resistors. The new circuit now employs
optically-isolated Bilateral Analog FETs, and is
fabricated on an additional circuit board.
Updates to the relevant sections of this manual are now
in process and will be available for shipment
approximately december 1993. This manual is completely
accurate with regard to specifications and operating
instructions. The circuit modifications are totally
internal and are completely transparent to the user.
End quote.
Nobody has the new manual.
One guy (TiN at xdevs and eevblog) has an updated instrument.
Another guy ("picburner" at eevblog) drew up a partial schematic,
https://www.eevblog.com/forum/metrology/teardown-fluke-845aabar-tweaks-and-mods-(and-repairs)/reply #14 March 7 2016 by picburner, attachment "845A_324_RevB.pdf" .
He got it almost right.
ERRATA
1. U2 pins 3 and 4 are K2 and A2, respectively. Therefore,
section 1 closes on positive and section 2 closes on negative.
2. For Q1 and Q2, the base resistor is R10 and R11 (1K); emitter
resistor is R12 and R13; pulldown resistor is R16 and R17 (10K).
3. The two H11F1's are U4 and U5. U5 pin 6 goes to CN8 BLUE.
U4 pin 4 goes to R15 (220 ohms) to CN7 ORANGE to R14 (20K)
to U5 pin 4.
4. U4 pin 6 goes to R7 (1Meg variable) to R6 (562K).
This is offset trim.
5. U3 is misdrawn. The input (marked pin 1) is actually pin 3.
The output (marked pin 3) is actually pin 1. R4 goes from pin 1
to ground, not pin 1 to pin 3. The junction of R5 and R6 goes
to pin 3.
6. I believe U3 is an LT1009 or LM336-2.5, wired as a negative
shunt reference.
Pin 3 is minus, pin 2 is plus, and pin 1 is trim.
It's not an LM385 whose pin 1 is a no-connect.
It's not a TL431 whose pin 2 is minus.
7. R3 is 2K not 1.6K .
PRINCIPLES OF OPERATION (speculative reconstruction)
DS101 and DS102 are removed.
R154 is changed from 33K to 6.5K.
C119 is changed from 0.22uF to 1uF.
Positive pulses from transformer T202 light transistor-output
HCPL2731 optoisolator U2 section one (A1/K1/C1) via R154, C119,
CR106, and ORANGE wire CN1 where DS101 used to go. Negative
pulses light section two via R154, C119, CR107, and YELLOW wire
CN2 where DS102 used to go. Where C119 used to create dead time
between DS101 and DS102 lit periods, now it ensures equal timing
even though T202's negative and positive peak voltage may be
different. The increased load on T202 reduces its peak voltage
to less than U1's max rating of 36V.
Positive pulses also power U1 (an LT1120A regulator)
via RED wire CN5, rectifier CR1, and reservoir/bypass C1 and C7.
We can't read the printing on R1, so we don't know Vcc for sure,
but it ought to be less than 18V, HCPL2731 optoisolator U2's max
rating. It's probably just 15V, being a separate supply to
keep current pulses off the original +15V unregulated rail.
(It was okay to use the old -15V rail to power U3, because
it's a constant DC load. +15V means that R1 is 1Meg.
Reducing R154 increases the current driving the LEDs inside U2.
The new R * C product is the same as before, but this is misleading;
with the low start voltage of the LEDs, each LED is lit for the
entire half-cycle. All the dead time comes from C4 and C5,
which also give a soft turn-on. (I don't know if that's
important.)
When T202 goes positive, U2 section one is lit, shorting
C1 (pin 7) to ground, discharging C4 and extinguishing U5.
Meanwhile, C2 (pin 6) opens, allowing C5 to charge and Q2
to light U4. The same action occurs on the opposite
components on the other half cycle.
Note that U5 is turned off (and U4 turned on) when DS101
used to illuminate V101, so the modulator and demodulator
have the opposite phase relationship to original construction.
This would reverse the meter polarity, so I am obviously
missing something.
C4 * R9 = 0.93ms .
With 15V, at phase begin, C4 or C5 charge at 16V/ms or
about 15mA/ms, but that doesn't continue. After 1ms we're
up to about 10V or 7mA which is still way past U4/U5 turnon.
Factoring in transistor and LED diode drop, we probably get
an actual dead time on the order of 100us, which is plenty
for the H11F1.
U3, an LT1009 or LM336-2.5 -2.5V shunt reference, provides
offset trim to U4 and U5. Minus pin 3 is powered with 6mA
from the -15V rail via R3. Plus pin 2 is ground. Trim
pin 1 is set by voltage divider R4/R5 which is wired across
Minus and Plus. I presume this zeroes out U3's temperature
coefficient, since they are two different resistor types.
U4 and U5 act as an SPDT switch with dead time in the
middle. U5 pin 6 or CN8 BLUE connects to the input
voltage on C103 in place of V101; U4 pin 6 or CN6 RED
connects to return/feedback in place of V102; their
junction, CN7 ORANGE, goes to the AC amp at C104.
When lit, U4 and U5 produce on the order of 100uV of
offset voltage, with source negative and drain positive.
Asymmetrical resistors R14 and R15 forming the common
point between U4 and U5 transmit the respective offsets
unequally, resulting in a net positive, which current
from U3 via R6 and R7 trims back to zero. The trim
current is adjustable from 1.6uA to 4.4uA, developing
16 to 44uV across R114.
