Hi Sandra, I'm glad I could help!
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
It was easy after your earlier posts helped me understand what you needed. And what kind of Mechanical Engineer would I be if I couldn't remove, separate, and reassemble the Rubidium oscillator and PCB?
I've broken some things mechanically in my life, but I've probably ruined more things with electrical or software mistakes.
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
Right now, I have a Spectracom SecureSync that lost its mind because I flashed the wrong EEPROM image to it. I hope to fix it someday, if possible.
Thanks for the information on PCB fabricators. I haven't used such services before, but I might in the future. For now, I look forward to a future post about your S350 running with the Rubidium oscillator!
Dean
You are awesome, thank you.
Those pics are far more than I had hoped for.
I will design and have the board fab'd by OHSPARK most likely. international shipping is a pain right now otherwise I'd use JCLPCB or PCBWAY.
The aluminum heatsink/spacer I will fab in my home shop..
