I could never get my hands on Ians original, but this must be a totally awesome continuation. I'm glad this project is in good hands again
I was wondering a bit about the newly added temperature sensor, but after looking at the
Certificate of Calibration which comes with the unit, the
Internal Temperature during Calibration is stated there as well in addition to the ambient temperature, so it all makes sense.
Another issue is that I cannot find any mentions about using non-rechargable 9V batteries. I found some article saying it's not recommended but there was no source or reason given (probably safety).
I don't have rechargable ones lying around, so I'm using Varta 9V Lithium with 1200mAh. Will last only about 24 hours though, so not ideal, especially considering the price of those.
Obviously I won't connect external power, and I've disabled charging in the options as well.
Then I had the idea to burn this in for a long long time (potentially years) which brings up a concern: Is there a MTBF or something specified for the display? Could it possibly be switched off per software? Or is this a non-issue?
