I was doing some hacking and have now enabled root logon via SSH
if there is a easier way feel free to tell me I wasting my time. And yes I know you can get a console port @ 9600 baud but ssh is nicer
otherwise
perform a backup and do a save-as to get a backup downloaded
open the backup in a zip until such as 7-zip
inside you will see config-1.2.tar.gz
open this in 7zip
then open config-1.2.tar in 7zip
you now have 2 directories
/etc
/var
go into /etc
open and edit shadow (the password file)
the root account looks like this
root:*:14012::::::
the * mean root can not logon
change to
root:$1$uV2.fU1.$UFcRU1rZDB5NJElVrwIR11:14012::::::
that will give root same password as admin (ie symmetricom)
save
if prompted to update the backup file do so
now go to /etc/ssh
edit sshd_config
find
PermitRootLogin no
change to
PermitRootLogin yes
save file
close the archive
go to the wizard and restore using the backup file you just updated
![Symmetricom S200 Teardown/upgrade to S250](https://www.eevblog.com/forum/index.php?action=dlattach;topic=96312.0;attach=945068;image)
