Author Topic: LH0070 / LM169 - die pictures  (Read 3000 times)
Offline NoopyTopic starter
    • Richis-Lab
« on: April 06, 2020, 08:31:57 pm »
Hi all!
I got a LH0070, a 10V-reference built by National Semiconductor:
 :wtf: A ceramic-@*#+%? ...I don´t know what is the english name for "Keramikträger".  ;D
There is a 56Ohm-resistor and a 3,6nF-capacitor in series at the output. It seems that the reference was unstable at higher frequencies and they had to damp it.
Hey, it´s a LM169! A reference that is a bit more accurate.
Does anybody know what that is? There is a fusible link but what is the big thing consisting out of two parts connected unter a metal block?
More pictures here:
https://richis-lab.de/REF09.htm
 :popcorn:
The following users thanked this post: lowimpedance, TiN, edavid, Andreas, chuckb, capt bullshot, iMo
Offline iMo
  • Country: bt
Re: LH0070 / LM169 - die pictures
« Reply #1 on: April 06, 2020, 09:08:10 pm »
"keramikträger" == "ceramic substrate" ?
The following users thanked this post: MiDi, Noopy
    • Richis-Lab
« Reply #2 on: April 06, 2020, 09:11:10 pm »
Yes! Thanks!  :-+ ;D
In fact in german also "Keramiksubstrat" is possible... Well too late for today...  ;D
Offline edavid
« Reply #3 on: April 06, 2020, 09:11:57 pm »
English speaking electronics engineers would call that a "thick film hybrid circuit".
    • Richis-Lab
« Reply #4 on: April 06, 2020, 09:13:20 pm »
Yes, also right!  :-+ Perhaps more right.  ;D
Offline iMo
  • Country: bt
« Reply #5 on: April 06, 2020, 09:40:16 pm »
"Thick film hybrid integrated circuits" are usually built on a "ceramic substrate"  :D
« Last Edit: April 06, 2020, 10:02:53 pm by imo »
Offline Theboel
  • Country: id
« Reply #6 on: April 07, 2020, 03:01:36 am »
stupid question Is this a good reference ?
I have some I pull out from old board
    • Richis-Lab
« Reply #7 on: April 07, 2020, 03:21:11 am »
Good morning!  :)
It is a ceramic substrate with a thick film resistor but there are also ceramic Substrates with thin film resistors!  ;D Because of that I usually use "ceramic substrate" that´s alway correct.  ^-^
Well, good, better, good enough… In my view it´s good. A voltnut would prefer a LTZ1000.
Offline Kleinstein
« Reply #8 on: April 07, 2020, 07:33:07 am »
It is a while I looked at it. AFAIR it is a relatively good one.  Roughly comparable to LT1031 or AD581 in a metal case.
    • Richis-Lab
« Reply #9 on: April 07, 2020, 09:43:44 am »
A moment ago I learned that the ceramic substrate is no surprise: LH stands for Linear Hybrid!  :-+
Offline Lemonizer
« Reply #10 on: April 07, 2020, 10:00:43 am »
Noopy, those are really nice pictures ! Thanks for that, makes me want to get a microscope sometimes :P
Ceramic caps/components got a bad characteristic for such voltage reference ? I don't know much about them, but I'm quite interested.
I do have a LM399 board I bought online, that I'm using as a sanity check for my various DMM's. I'd love to build a few myself in the future !
    • Richis-Lab
« Reply #11 on: April 07, 2020, 10:48:36 am »
Thank you!  ^-^
There are a lot of different types of ceramic caps. You can also buy very good ceramic caps.
But I don´t think that is a problem here. The RC doesn´t stabilize the voltage it musst only short the output if the frequency gets to high. That´s a very easy task.
Offline edavid
« Reply #12 on: April 07, 2020, 02:07:29 pm »
I suspect there was an earlier version with more than one IC on the hybrid, before they integrated it into the LM169.
Offline schmitt trigger
  • Country: mx
« Reply #13 on: April 07, 2020, 02:21:26 pm »
Noopy;
thanks again for taking us to the wonderful world of micro electronics.
Back when National Semi was a major player, their prefixes in their part numbers made a lot of sense:
LM= Linear Monolithic
LH= Linear Hybrid
DM= Digital Monolithic
LF=  Linear Fet
LMC= Linear Monolithic CMOS
And so on.
I read somewher that this was a carryover from Fairchild with their  uA = micro analog prefixes.
« Last Edit: April 07, 2020, 02:24:45 pm by schmitt trigger »
    • Richis-Lab
« Reply #14 on: April 07, 2020, 02:39:23 pm »
Sounds reasonable!  :-+
Noopy;
LH= Linear Hybrid
LF=  Linear Fet
And so on.
Thanks!  :-+
Offline kleiner Rainer
  • Rainer DG1SMD JN48ts
« Reply #15 on: April 07, 2020, 04:26:24 pm »
If you look at the datasheet of most regulators/references you will find that the output impedance is rising with frequency. This means the output impedance is inductive. Depending on load and output capacitor size, you get a nice noise voltage bump at the resonance frequency of the resulting series LC circuit. One way to mitigate this is to put a resistor in series with the cap and destroy the Q of the LC circuit. I suspect this is the case here.
Greetings,
Rainer
Offline edavid
« Reply #16 on: April 07, 2020, 06:02:52 pm »
Not exactly - the explanation is on the LM169 datasheet:
The output can sink current as well as source it, but the output impedance is much better for sourcing current. Also, the LM169/369 requires a 0.1μF tantalum capacitor (or, 0.1μF in series with 10Ω) bypass from the output to ground, for stable operation in shunt mode (output sinking current).
« Reply #17 on: April 07, 2020, 06:56:18 pm »
I had this text in mind:
https://electrooptical.net/static/oldsite/www/sed/ErrolDietzRegulatorNoisePeaks.pdf
Could be useful if you need a low noise reference (or low noise in a certain frequency range).
Greetings,
Rainer
