Author Topic: Sources of information (ie books) on polishing and lapping  (Read 1255 times)
Offline jeremyTopic starter
Hi all,
Not sure if this is the right area to ask this in, but it is concerned with unreasonable levels of pedantry, so I thought this might be the best  ;)
I’m looking for some books and other sources on lapping and polishing techniques. In particular, making first surface mirrors, and also for making parallel/precise angled and flat surfaces on various metal objects.
If anyone can point me toward some classics that would be great!
Offline Andy Watson
Re: Sources of information (ie books) on polishing and lapping
« Reply #1 on: May 23, 2019, 01:14:51 pm »
John Strong's book "Procedures in Experimental Physics" covers the basics. It's a bit old but the techniques are still valid. You might also look at books on telescope construction - Jean Texereau's "How to Make a Telescope" for example.
Offline RandallMcRee
« Reply #2 on: May 23, 2019, 02:36:25 pm »
The classic is "Amateur Telescope Making vols 1,2,3 by Ingalls.
https://www.willbell.com/tm/tm7.htm
Distilled knowledge is here:
http://bobmay.astronomy.net/johnpierce/part8.htm
this search returns good stuff "amateur telescope making optical flats"
Offline coppercone2
« Reply #3 on: May 25, 2019, 01:23:19 am »
