NOTE: Question has been moved here from "Project, Design and Technical Stuff" since the nature of the question may be more metrology related. Hope I didn't do something wrong in the while (first time using this forum)
Hi folks,
I had been reading around on this forum for some time, and this is the first time I write a post, hope to do everything right.
Since some time I started to be interested in voltage references (I know that technically this post may fit in the Metrology section, but here my problem lies mostly on how to design a certain part which should be more general, hence I preferred posting it here). I'm quite a newbie
Some time ago I found these two "references" (not that high end, since it's based on something that is not mainly a proper voltage reference, but I'm starting just now in the field, so I think it may still be good for me. Performances I'd like to achieve are below):
- Elektor 723 Voltage Reference, from July 1978 (project no. 99 on this paper)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiUnYXw8of4AhUj_rsIHZeVDm0QFnoECAIQAQ&url=https%3A%2F%2Fworldradiohistory.com%2FUK%2FElektor%2F70s%2FElektor-1978-07-08.pdf&usg=AOvVaw0T7Njj0aodbUGTjAGLrvrd- This website, in which there is another approach
https://electronicprojectsforfun.wordpress.com/silly-circuits/silly-circuits-a-heated-lm723-reference/The projectGenerate that voltage (around 7V), buffer it through an op amp (OP07 should be okay for the job, I hope) and then divide it, in order to feed it into an ADS1115 (can handle max. around 6.1 V with a 2/3 gain, hence I have to use some divider for that) and monitor it through Arduino. The contour in this project is also to learn something about Python and Grafana (or some sort of software like that) in order to post process some results, but that's just a contour and explained it just to give a context. Since it's just a starting project about "precise measurements" and related stuff, I'd like to keep it as low cost as possible.
Requirements- Manage to have readings down to millivolts (don't mind going further), hence the ADS1115 should be sufficient, with a resolution of 125 uV @ Gain = 1
- Manage to implement a correct filtering and buffer, which hopefully reduces the noise on the system and smoothen the output a little bit (unless somehow I'm doing something wrong and actually ruining the measure and/or increasing the noise, which I shouldn't, according to OP07 datasheet)
My approachWhat I came up with is the following:
As a first note, on the future PCB there will be also be a regulator based on the LM350 (I have some of them lying around which I never use, and are not drawn in this schematic since this part is completely done as per datasheet indications). This because the only generator I have is an adjustable one I built and is not that much great in terms of regulation (and since here I need a fixed voltage but with relatively good regulation, I went with an on-board one). The idea is to power it with my generator, but regulated much better with the on-board one. I know this isn't optimal, but it's basically the only equipment I have.
The reference part is pretty straightforward with the Elektor project. I added a simple low pass filter in order as most high frequency AC as possible (cutoff at 1.85 Hz) using a carbon 1% resistor and a polypropylene capacitor. I'm not really sure about the buffer, however. My idea was to have a voltage follower, with a divider in order to have around 3.5V, which is the only way that comes into my mind that can be treated by the ADS1115. Note that all my following reasoning is based on this design, but I'm open to better configurations if there are any. So, here are my questions:
About the voltage followerFrom the 2nd project linked above I decided to give it a try to the OP07, which, according to the datasheet (linked below) it has a low offset (max 75uV, below my requirements) and offset correction pins, which in this case should be enough, and noise shouldn't be a problem. I don't know if there are any better op configurations which could be used here for a buffer in order to feed the divider (different from the follower, maybe more used in metrology field). I've obviously used op amps in other projects, but this is quite the first time I'm trying to consider every possible behaviour, so sorry if I miss some point.
On a side note, according to the datasheet I see that they recommend connecting the central pin of the pot to VCC. Doing some general testings (done with 3.3V, and checked the two inputs with two ADS1115 pins), I actually managed to reduce the offset by connecting the pot central pin to GND instead. According to the following document from TI, from what I can understand they connect the middle pin to GND, so I don't really get why they recommend VCC in the OP07 datasheet. Is this something that depends on the opamp, or am I missing something?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiM7KCln4j4AhXE7rsIHTlRDt0QFnoECAYQAQ&url=https%3A%2F%2Fwww.ti.com%2Fgeneral%2Fdocs%2Flit%2Fgetliterature.tsp%3FbaseLiteratureNumber%3Dsloa045&usg=AOvVaw2N6EOfOGY7akq1COnSqZcrAbout the voltage dividerUnfortunately, I don't have any precision resistors lying around (the best I have are 1% metallic resistors, and only 10k). I don't know how much that helps, but I thought about this: since my 10k are 1%, this means that this divider in the "worst case" (maximum difference between the two) will be 10100 ohms and 9900 ohms. Supposing the output is 7V, I can have an output voltage on the divider between 3.535V and 3.465V (so, undertainity in the 10s of mV). With some 0.1% resistors (which I would have to buy), I will go between 3.5035V, so I would still be in the mV uncertainity. Note that obviously I know about the 3.5etc V; what I don't know, and that I would like to, is about the 7V above.
How I thought to solve the divider problemNow, I know that I can simply analyze the 3.5V and see how is the behaviour of that (aka. having a sort of "reference" at 3.5V), but I'd like to reconstruct the full 7V considering the variability of the resistors. For this purpouse, I thought to mount the 10k first and add various pins both on the output and on the divider, in order to "test" the resistors with some known voltage, like the 5V from Arduino. I know that even those 5V aren't perfect, but since in this case I can both recover 5V and 2.5V with the ADS1115 with sufficient precision, I could theoretically easily recover the ratio of the two outputs, and hence the ratio of the resistors. I don't know if this is an overkill, a wrong procedure or something else, but isn't this conceptually right? I know that there are more in-depth considerations (like tempco), but as a starting point, a proper PCB design (keep the divider distant from other heat sources, like in this case the 723 itself, and keep them close to have the most uniform temperature) should be enough, right?
I honestly can't think of any other alternative for now, since for this I thought that maybe the simplest approach (assuming that I can somehow solve its uncertainities) is just enough, but I'm open to alternatives of there are any.
COMPONENTS DATASHEETS
- ADS1115
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjU9rSIr4j4AhWfQvEDHTc3BOYQFnoECAQQAQ&url=https%3A%2F%2Fwww.ti.com%2Flit%2Fgpn%2Fads1114&usg=AOvVaw1uY1d0MAXekJgc17vRTqG6- OP07
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiTnvSVnYj4AhVmhf0HHW6hBeYQFnoECAUQAQ&url=https%3A%2F%2Fwww.analog.com%2Fmedia%2Fen%2Ftechnical-documentation%2Fdata-sheets%2Fop07.pdf&usg=AOvVaw1Hrllw_v2B6WbReKi_KBjS
