Let me preface this by saying that I am not a metrology expert. I'm just a hobbyist. If you are (or think you are) an expert, take this into account and don't jump down my throat if I don't explain what I am doing in the correct way. My intention is to share what I am doing so that I may learn more and perhaps others may learn from what we all post here. This was just an exercise in comparing the three bench meters that I have to see how closely they agree.
I "assumed" the 3457A as my standard so as not to over complicate my explanation. I'm sure some of the metrology experts would have explained it better. If you take the 30 VDC specs for the 3457A into account, the two Siglent meters still exceed their published spec for the voltage I measured.
As for my 3457A being within spec, I sent it in with all cal constants gone, as I purposedly didn't bother saving them when I changed the battery. In fact, I don't know if there were any valid cal constants in the first place. The battery had previously been changed by the last owner. The cal lab had to do the entire adjustment procedure in the service manual and not just a verification. The tech I spoke to had to spend an extra hour because of this.
Yes, it would be better if I had a 3458A and a Josephson Junction to calibrate it against. Can't afford those, so I use the best that I can afford (I spend too much as it is). The point I was trying to make was that the two Siglent meters seem to be well within spec at the DC voltage I measured. I have not checked other ranges yet, as my EDC VS330 needs to be sent off for calibration next.
And I know that the VS330 has a similar spec to the 3457A. Again, I should have a 3458A to check the VS330. Maybe if I win the lottery. In reality, the 5-1/2 digit meters are more than sufficient for any hobby work I do.
I'm going to buy some 0.01% resistors soon, so I can check my meters against those. And maybe I'll build a current reference, as Dave showed in some earlier videos.
I know that there are some here who have much better standards and a better understanding of metrology. I'd just thought I'd report the results of my testing. If I have made errors, I would welcome feedback, pointing out those errors.
