Don't play with uranium. If such high radiation intensity surrounded your patterns, this problem would no longer concern you. Leukemia would simply kill you faster if you saw a measurable effect. ...
I had an interesting experience buying the Uraninite ore sample from Amazon. According to the listing it was safe to ship via USPS:
Packaging and shipping of the radioactive material comply with the “USPS Packaging Instruction 7A” on shipping of a ‘limited quantity’ of “natural” radioactive materials
specified in 49 CFR 173.42 in the USPS publication 52.
On arrival here, Australian Customs questioned it. I pointed them to the Amazon listing, and Customs let it through.
Testing the sample now, located in its closed metal container: detector sitting on the container: 0.7 uSv/hr (5 x background);
With one mild steel sheet (coffee can lid) in between closed container and detector: 0.5 uSv/hr
With two mild steel sheets: 0.5 uSv/hr (same as one sheet)
So it looks like the mild steel blocks some emission types (alpha particles?), but not all (gamma radiation?).
https://www.radetco.com/your-complete-guide-materials-that-block-radiation/
