Hi, I tried to make a dump on my 3457A that uses the firmware and the board that I attach in photos, I use the PROLOGIX interface and HP3457A Memory Dumper.zip (Thank to 0xfede), I often have difficulty doing it with win10-64b where it goes wrong when saving the file , with win10-32b it makes the rescue regularly. The multimeter has the firmware 03457-88810 Rev2 (If someone interested I have the .bin of the eprom).
I noticed that if I do more 'dump and compare the content is different, only some parts match, do you have any advice to give me?
Hello,
Got my 3457A today, looks like it is in very good shape. Includes calibration certification until 10/2020. 10V voltage reference around -39uV off (9.99961V). Agilent 34410A shows exactly 10.00000V calibration valid until 10/2017. Which one would you trust?
Ad Cal Dumping: I experienced similar problems dumping the 3457A with HP3457A Memory Dumper.zip (Thank to 0xfede). I use the PROLOGIX interface under Win10-64Bit. Didn't try Win10-32Bit yet (no machine).
Serial number SN#: 2703A06XXX
Battery voltage of Saft Lithium LX1634 (looks original): 3.0328V
EPROM: 03457-88810, D/C 8825
Main Controller: 03457-66511 Rev A 88809F
Input Signal Conditioning, A/D Converter, Inguard Controller: 03457-66502 Rev C 88809F
AC Converter: 03457-66503 Rev B 88809F
Reference voltage board: 03456-66525 Rev B 88809F
Keyboard board: 03457-66505 8809F Rev A
Guess EPROM D/C 8825 means datecode year 1988/week 25, right (according to the chips datecodes and serialnumber/productrevision that looks ok)?
Cal Dump #1 has 451 bytes, Cal Dump #2 has 453 bytes.
Any ideas?
Something special to configure in the Prologix Setup?
BTW: Is it normal that the 4 screws of the Main Controller are missing (so it is not screwed)?
@0xfede: Any chance to release the source code of the dumper?
@ipqobk: I'm interested in the firmware 03457-88810 Rev2 dump. Whats the latest one for Rev. A boards?
Thnx.
Wiesl
