Phew, 4920M is back home now...
mini Cal-fest TW was a blast, very happy with this weekend. Spent 20 hours or so cooking python snakes, talking to calibrators and Fluke AVMS, and learning 4920M cal quirks.
I now sorta understand why Tektronix wanted 7000$ for 4920M cal.
Did not had enough time to run WB cal or extra steps, so I'll still have to calibrate few things, but I can do those at home using my 3245A and 3458A w/Swerlein's algorithm for precise AC.
Most difficult high voltage ranges are calibrated now. I ran both low-level calibration and user calibration as you may remember, cal rom was erased in this unit.
I'll post more info once I get everything prettified.
Btw, 4920 is very capable instrument. During second user-cal check, I was watching for readings, they match well <10ppm on each range/freq (1kHz,1MHz) to 5790A. So these old gems are truly capable.
