Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Metrology
Restoration : Wavetek 4920/4920M teardown, repair and usage cases, come join!
« previous
next »
Print
Search
Pages:
Prev
1
2
3
4
5
All
Go Down
Author
Topic: Restoration : Wavetek 4920/4920M teardown, repair and usage cases, come join! (Read 44737 times)
chinapp
Contributor
Country:
Re: Restoration : Wavetek 4920/4920M teardown, repair and usage cases, come join!
Reply #100 on:
May 30, 2022, 06:51:58 am »
is it means fix the cut trace can make the mV option on ?
Logged
http://
TiN
Super Contributor
Country:
Reply #101 on:
May 30, 2022, 08:26:04 am »
Making meter "detect" mV option will not magically add missing components, no?
Logged
YouTube
Metrology IRC Chat room
| Let's share T&M documentation?
Upload
! No upload limits for firmwares, photos, files.
chinapp
Contributor
Country:
Reply #102 on:
August 17, 2022, 10:58:00 am »
seems no more info on this ............
Logged
http://
meandeev
Regular Contributor
Country:
Reply #103 on:
August 18, 2022, 06:56:10 pm »
Hello,
was there somebody in and removed some components?!
Attached you can find a photo of the mV-option of my 4920 and also the 400978-2.5 firmware of this device (Sticker says 2.5, inside the firmware you can find the number 2.05)
Logged
chinapp
Contributor
Country:
Reply #104 on:
August 27, 2022, 09:22:14 am »
thanks so much for your pic
it seems not a big problem, could you give a view of the five transistors? can not get the model of them,and also the foil resistor beside the fuse
Logged
http://
chinapp
Contributor
Country:
Reply #105 on:
June 09, 2023, 09:54:19 am »
recently research update >>>
the main board of none mV option 4920 is different to the mV option added 4920,so it seems there is no way to update
Logged
http://
Print
Search
Pages:
Prev
1
2
3
4
5
All
Go Up
« previous
next »
Electronics
Metrology
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
