I wrote some scripts to crawl the ebay pages of seller "hifi-szjxic" (
http://stores.ebay.com/hifiaudioic/) and list all of his resistors, dividers, etc, in formats which are a bit easier to browse.
These scripts run every day just before 9AM central, so these lists will be updated daily.
Here's a list of all of his metal foil resistors, sorted by resistance value. The format is (resistance value, description of the listing). I haven't added support for links yet, so if you see something you want, you'll have to copy/paste the description into his store search box.
https://ssl.pepas.com/hifi/resistors.txtHere's the above list, but only entries which contain the letter "Z":
https://ssl.pepas.com/hifi/resistors-z.txtHere's the list of ratios (between 12:1 and 13:1) which can be made using pairs from the above list of resistors:
https://ssl.pepas.com/hifi/resistor-ratios.txtSame thing, but where both resistors in the pair contain the letter "Z":
https://ssl.pepas.com/hifi/resistor-ratios-z.txtFinally, here's the list of all of the dividers he sells, sorted by ratio:
https://ssl.pepas.com/hifi/dividers.txtHopefully these will be useful for other LTZ nuts on a budget
