Hello all,
I am looking at the attached table, extracted from the detailed specifications of the Fluke 8845A multimeter; and I cannot correlate the figures for the shunt resistance and burden voltage. Take the 10mA, 100mA and 400mA ranges, for instance. They all share the same 1Ohm shunt. At 100mA, the voltage drop would be just 0.1V, not 0.25V.
I understand that this burden voltage would also include the voltage drop on fuse and contacts, but even then, I would expect that the burden voltage for 400mA is 4 times higher than the one for 100mA and it is not. It is just double.
Why is it so?
Regards,
Cristian
