Author Topic: Ref80 - A competition to ADR1001?  (Read 1014 times)
Offline branadicTopic starter
  • Sounds like noise
« on: September 23, 2024, 05:23:24 pm »
"REF80 is a buried zener, internal heater compensated voltage reference. The device is designed with an extremely low temperature drift and long-term drift. REF80 is also a low noise device."
https://device.report/m/158081276c8014e611d4be1e2e7e80c15bf10773f92c56a97763852ea16d52fd.pdf
Has TI really worked on a competition to ADR1001? HP3458A reading in figure 2-3 indicates a zener voltage of 7.577 V. :-//
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
The following users thanked this post: Echo88, Mickle T., Andreas, doktor pyta, gamalot, bsw_m, iMo, mendip_discovery
Offline mendip_discovery
Re: Ref80 - A competition to ADR1001?
« Reply #1 on: September 23, 2024, 05:43:48 pm »
-branadic-
oooh, that sounds interesting. I guess AD have kinda dropped the ball a bit with the ADR1001 as they have only managed to produce a new ref much like the old one but not as good (YMMV).
Looks like this is very early info so will wait to see what happens.
EDIT:
Looking at the site there is a REF70,
https://www.ti.com/lit/ds/symlink/ref70.pdf
Long-term stability: 1k hrs: 35 ppm
Coefficients: 2ppm per deg C
even newer is the REF54,
https://www.ti.com/product/REF54
« Last Edit: September 23, 2024, 06:00:38 pm by mendip_discovery »
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline iMo
  • Country: bt
« Reply #2 on: September 23, 2024, 06:21:20 pm »
Let us wait on REF90.. With the opamps and 5V/10V dividers in the oven.
What is interesting to see is the pcb layout of the eval kit - how are the slots around the package arranged..
Offline jbb
« Reply #3 on: September 24, 2024, 12:15:11 am »
Having another vendor for high precision references would be welcome.
I wouldn’t expect a drop-in replacement, but having a competitor to Analog Devices in the game is a good thing.
Offline laichh
  • Country: my
« Reply #4 on: September 24, 2024, 02:49:59 am »
Identical file was found on ti.com domain:
https://www.ti.com/lit/ug/snau304/snau304.pdf
From the schematic in Figure 4-1, this REF80 doesn't have the derived output (+5 V, +10 V...) like the ADR1001, only the zener output at ~7.6 V is available.
Traditionally, TI's alternative is often (if not always) cheaper than ADI. ADR1001 1ku listed price on ADI is $66.34, I would expect this REF80 to be range between $35 ~ $50 each.  :-//
Online ArdWar
  • Country: sc
« Reply #5 on: September 24, 2024, 05:22:09 am »
Interesting, the pinout is MostlyCompatible™ with ADR1001.
Is this TI's first foray into buried zener technology? I don't think their other references are buried zener (LMx99 don't count ;D)
Offline Andreas
« Reply #6 on: September 24, 2024, 05:35:13 am »
What about REF102 (Burr Brown Division)?
Offline 3roomlab
« Reply #7 on: September 24, 2024, 06:31:59 am »
nice
the slotting they use is so small
like size of the 2.54mm pin (~ 0.4mm ?)
* mr imo is right, more like 1mm slot
« Last Edit: September 24, 2024, 08:32:17 pm by 3roomlab »
Offline Kleinstein
« Reply #8 on: September 24, 2024, 07:23:13 am »
The REF102 is a nice 10 V reference, but the metal case seems to be no longer available.
How good the Ref80 will actually be is still unclear. There is not even a preview data-sheet. It may as well be more competing with the LCC version or the ADR1399.
The slightly higher voltage is a bit odd and rather high for zener plus PN junction.
Offline iMo
  • Country: bt
« Reply #9 on: September 24, 2024, 12:36:07 pm »
nice
The pitch of the package pins is 1.27mm. Thus the slots are aprox 1mm wide, imho.
The slots' layout seems to help with the mechanical stress as well.
So let us copy that layout for the ADR1001 as well..
Offline Kleinstein
« Reply #10 on: September 24, 2024, 01:20:10 pm »
The slots are for mechnical stress and to keep the thermal loss low, though much of the heat loss can still be via the copper traces. It thus makes sense to have separate drive and sense pins for the output and also separate grounds for the reference and the heater.
Offline iMo
  • Country: bt
« Reply #11 on: September 24, 2024, 01:27:09 pm »
I've been planning the pcb for 2y already  :D and perhaps the other owners do too, let us continue in the ADR1001 thread and let us design the pcb finally..
