I bought an Agilent 82357B GPIB interface, probably a clone because it was cheap, and tried to use it with the logging platform. For this first I downloaded the latest Raspbian image, based on Debian 9 (Stretch), from this week, 2017-08-16-raspbian-stretch-lite.img. I've done the steps from
https://raw.githubusercontent.com/PlesaEEVBlog/RPi_LogNut/master/Install_GPIB_Support.sh (maybe this should be renamed, because it does more, like updating the distribution, installing USBTMC etc.) manually to see if something went wrong and it worked mostly, even the linux-gpib driver could be compiled with the new Linux kernel version 4.9.41. One thing missing was the "pip" package (needs an additiona "sudo apt-get -y install python-pip"). Note: to enable SSH remote login, create an empty file "ssh" on the "boot" partition. Then you can login with the user "pi" and the password "raspberry" with ssh (or use
putty from Windows).
Then I had problem to use the GPIB interface. When plugged in, "lsusb" showed "Bus 001 Device 004: ID 0957:0518 Agilent Technologies, Inc. 82357B GPIB Interface". I think the firmware load step was necessary, as described here:
https://xdevs.com/guide/agilent_gpib_rpi/ . Bus 1 and Device 4 means, I had to do this:
fxload -t fx2 -D /dev/bus/usb/001/004 -I /opt/gpib_firmware/gpib_firmware-2008-08-10/agilent_82357a/measat_releaseX1.8.hex
After this command, the RPi hung, and stopped always after reboot. Turns out I had a power problem, maybe because of my cheap GPIB clone, or it needs really a lot of power. I could fix this by desoldering F3 on the RPi, near the power supply USB port, and short it with a nice big 1 mm silver wire, and then powering it with a good 3A USB power supply. You can see the location here:
http://www.tooms.dk/forum/topic.asp?TOPIC_ID=286 My RPi (a Raspberry Pi 1 Model B) doesn't have fuses near the output USB ports, but mounting holes, but if you have a model with F1 and F2, you might need to bridge these fuses as well. No more crashes now after shorting the fuse!
After the first flash (and some reboots because of the power problem), lsusb showed "Bus 001 Device 010: ID 0957:0718 Agilent Technologies, Inc.". So the second flash, as described on the website, was this: "fxload -t fx2 -D /dev/bus/usb/001/010 -I /opt/gpib_firmware/gpib_firmware-2008-08-10/agilent_82357a/measat_releaseX1.8.hex". Then another power cycle, just to be safe. Now lsusb shows this: "Bus 001 Device 009: ID 0957:0718 Agilent Technologies, Inc.".
And then the gpib_config command succeeded. Output of /var/log/syslog:
Aug 18 19:06:40 raspberrypi kernel: [ 202.257222] gpib: no gpib board configured on /dev/gpib0
Aug 18 19:06:40 raspberrypi kernel: [ 202.257328] gpib: no gpib board configured on /dev/gpib0
Aug 18 19:06:40 raspberrypi kernel: [ 202.257365] gpib: no gpib board configured on /dev/gpib0
Aug 18 19:07:07 raspberrypi kernel: [ 229.381524] attached to bus interface 0, address 0xd94ae600
Aug 18 19:07:07 raspberrypi kernel: [ 229.406328] agilent_82357a_attach: attached
After this I could mount my samba share of my NAS system as usual with "mount.cifs //my-nas/share /mnt -o user=user,pass=password", which makes it easier to edit programs on my host PC. Then I started the Test_GPIB.py script. I tested it with my new Fluke 8842A, which doesn't have the "*IDN?", but sending a "G8" resulted in "FLUKE,8842A,0,V3.0"
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
Finally I wrote a simple test script, which selects the 20 V range and prints the voltage measurement every second, see this file:
https://github.com/FrankBuss/RPi_LogNut/blob/master/pub/python/Fluke-8842A.py(I really like the Fluke, 100 uV resolution in the 20 V range)
This will be available in plesa's repository, together with some other scripts and bugfixes by me and others, when he merges my pull request:
https://github.com/PlesaEEVBlog/RPi_LogNut/pull/1plesa, if you merge the pull request, you might need to move the files from /pub/python to /python, if different or new, because in your repository is no /pub/python directory.
