root@raspi2:/home/bingo# ./idn1.py
Traceback (most recent call last):
File "./idn1.py", line 4, in <module>
import Gpib
File "/usr/local/lib/python2.7/dist-packages/Gpib.py", line 2, in <module>
import gpib
ImportError: libgpib.so.0: cannot open shared object file: No such file or directory
**** I missed the ldconfig
root@raspi2:/home/bingo# ldconfig
KEITHLEY INSTRUMENTS INC.,MODEL 2015,1043877,B15 /A02
**** Success on Noobs 1.4.1 - on a Raspi v1 - I disabled devicetree under advanced , but am not sure if it's needed
https://downloads.raspberrypi.org/NOOBS/images/NOOBS-2015-05-12/uname -a
Linux raspi2 3.18.0-trunk-rpi #1 PREEMPT Debian 3.18.5-1~exp1+rpi19 (2015-08-08) armv6l GNU/Linux
Using my "old recipee"
https://www.eevblog.com/forum/reviews/using-a-raspberry-pi-with-linux-gpib-and-a-beiming-or-agilent-usb-gpib-adapter/msg329067/#msg329067TIN's: Might be clearer
https://xdevs.com/guide/agilent_gpib_rpi/Basically install Noobs 1.4.1 then do a :
1: sudo apt-get update
2: sudo apt-get upgrade
3: reboot
4: sudo apt-get install linux-image-rpi-rpfv (If you are using newer Raspberry Pi 2, please use linux-image-rpi2-rpfv)
5: reboot
6: sudo apt-get install linux-headers-$(uname -r)
Rest from the recipee
Remember
sudo apt-get install fxload
Kernel stuff to append to /boot/config.txt (Kernel version dependant , look in /boot for the latest kernel installed)
# Set params for "raspbian debian-style kernel" boot
kernel=vmlinuz-3.18.0-trunk-rpi
initramfs initrd.img-3.18.0-trunk-rpi followkernel
Ohh - Seems like the udev "autoload firmware doesn't work"
I had to do the loads manually
******** Load firmware begin ********
lsusb
Bus 001 Device 005: ID 0957:0518 Agilent Technologies, Inc. 82357B GPIB Interface
/dev/bus/usb/001/005
#Load fw 2 times , but the id changes after first and second load
fxload -t fx2 -D /dev/bus/usb/001/008 -I /usr/share/usb/agilent_82357a/measat_releaseX1.8.hex
fxload -t fx2 -D /dev/bus/usb/001/009 -I /usr/share/usb/agilent_82357a/measat_releaseX1.8.hex
lsusb after 2'nd load
Bus 001 Device 010: ID 0957:0718 Agilent Technologies, Inc.
sudo gpib_config
If : gpib_config: error while loading shared libraries: libgpib.so.0: cannot open shared object file: No such file or directory
You missed the : ldconfig
*** From syslog ***
Dec 17 11:43:55 raspi2 kernel: [ 713.777579] usb 1-1.2: USB disconnect, device number 10
Dec 17 11:43:55 raspi2 kernel: [ 713.778097] agilent_82357a_driver_disconnect: exit
Dec 17 11:43:57 raspi2 kernel: [ 715.511199] usb 1-1.2: new high-speed USB device number 11 using dwc_otg
Dec 17 11:43:57 raspi2 kernel: [ 715.600619] usb 1-1.2: New USB device found, idVendor=0957, idProduct=0718
Dec 17 11:43:57 raspi2 kernel: [ 715.600658] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
Dec 17 11:43:57 raspi2 kernel: [ 715.600677] usb 1-1.2: Product: 82357B ()
Dec 17 11:43:57 raspi2 kernel: [ 715.600694] usb 1-1.2: Manufacturer: Agilent Technologies, Inc.
Dec 17 11:43:57 raspi2 kernel: [ 715.600712] usb 1-1.2: SerialNumber: MY49450180
Dec 17 11:43:57 raspi2 kernel: [ 715.611862] probe succeeded for path: usb-bcm2708_usb-1.2
Dec 17 11:43:57 raspi2 /etc/hotplug/usb/agilent_82357a: entered for Product: 957/718/0 Device: $devnode Serial: MY.... Devpath: /devices/platform/bcm2708_usb/usb1/1-1/1-1.2
Dec 17 11:50:49 raspi2 kernel: [ 1127.274586] attached to bus interface 0, address 0xd9806800
Dec 17 11:50:49 raspi2 kernel: [ 1127.281251] agilent_82357a_attach: attached
******** Load firmware end ********
Remember to make your user member of the gpib group ,
and put agilent_82357a in /etc/modules
Hmm .... Seems like i have to do a : sudo chmod 666 /dev/gpib*
Even though i'm a member of the gpib group .. strange
/Bingo
