Hi Plesa and the group,
I'm a complete RasPi beginner but I'm very interested in getting one set up for datalogging! I've followed the instructions to:
download raspbian-2017-03-03/2017-03-02-raspbian-jessie.zip, Restore it to SD card and run script in terminal:
curl
https://raw.githubusercontent.com/PlesaEEVBlog/RPi_LogNut/master/Install_GPIB_Support.sh | sudo bash
It took quite a while to execute the script - longer than I was willing to watch. When I returned some time later the last entries on my terminal were:
Collecting si-prefix
Downloading si-prefix-0.5.tar.gz (49kB)
100% |?
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
?| 51kB 467kB/s
Building wheels for collected packages: si-prefix
Running setup.py bdist_wheel for si-prefix ... done
Stored in directory: /root/.cache/pip/wheels/7b/e3/f0/6c628d1ed2fe11531947b4d759bb61a39f45bf50da106d15f1
Successfully built si-prefix
Installing collected packages: si-prefix
Successfully installed si-prefix-0.5
depmod: ERROR: could not open directory /lib/modules/4.4.50-v7+: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
failed to open device file '/dev/gpib0'
main: No such device or address
pi@raspberrypi:~ $
It seems to have stopped due to an error. I looked in the file system and /dev/gpib0 does exist. However I have /lib/modules/4.9.35-v7+ NOT 4.4.50-v7+
Any advice would be greatly appreciated!
Also, how do I use the raspberry Pi once everything is installed happily? Sorry, but I need the hand-holding (at least to begin)
