Author Topic: Quark multimeter  (Read 2221 times)
Offline MegaVoltTopic starter
  • Country: by
Quark multimeter
« on: August 13, 2021, 11:59:29 am »
I got this project: it looks very interesting.
https://www.crowdsupply.com/mulin/quark
« Last Edit: August 13, 2021, 12:01:53 pm by MegaVolt »
Offline fcb
    • Electron Plus
Re: Quark multimeter
« Reply #1 on: August 13, 2021, 02:54:35 pm »
That sharp end will either break off, or stab you when you are least expecting it, etc... They need to make it retractable or removable/replaceable.
Also, the grounding - this happens through the USB port? 3.3A?
Offline guenthert
« Reply #2 on: August 13, 2021, 04:34:51 pm »
Shouldn't that go into the Test Gear section?
Offline TimFox
« Reply #3 on: August 13, 2021, 04:42:31 pm »
That looks like how the junior engineers (before I retired) used scope probes:  first, lose the “witch’s hat”, then put the ground wire aside, then lose the ground wire, then return the useless probe to whence it was borrowed.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #4 on: August 13, 2021, 05:16:18 pm »
It shows the SMD number code and color code of components based on their resistance or capacitance from some internal library - that's interesting ...
Offline Kleinstein
« Reply #5 on: August 13, 2021, 05:27:11 pm »
The input does not look very fast, so the long ground lead may not be such a problem.
The display at the end of the probe can still be a bit unconvenient - you just don't see the tip anymore. With a wireless display it may be OK - though more like a tiny, limited frequency scope and not a DMM replacement.
The still have to invent the wireless ground lead.
Online The Soulman
  • The sky is the limit!
« Reply #6 on: August 13, 2021, 06:19:35 pm »
Ground is likely (high impedance) ac coupled thru the operators hand.
Online Kean
    • Kean Electronics
« Reply #7 on: August 13, 2021, 08:14:30 pm »
Or even better, the Crowd Funded Projects section.
Offline bdunham7
« Reply #8 on: August 13, 2021, 08:18:28 pm »
Measures voltage from 0 to 26 V
Measures current from 0 to 3.2 A
Measures resistance from 0 to 2 MΩ
Measures capacitance from 2 pf to 1000 uF
Measures inductance up to 1 H
Oscilloscope has a sampling rate of 400 kHz
The following users thanked this post: The Soulman
Online The Soulman
« Reply #9 on: August 13, 2021, 08:42:09 pm »
Not if it does more than only producing wobbly lines on a tiny screen.  :-//
I do wonder what that factory makes during the Saturday afternoon shift, or this is it.  :palm:
Offline tszaboo
« Reply #10 on: August 13, 2021, 10:02:40 pm »
This is one of those objects that are useless without extra things that completely break the design.
