Hello cellular,
thanks so much for your very quick actions developing this nice little board. The performance ist outstanding but same time by its through-hole construction very uncomplicated to build. Also thanks to Andreas, and all the others, who are involved in the underlying work.
Some thoughts for this todos, to make the board slightly smaller in one dimension to fit within a TEKO case.
These cases are also available in different versions:
- TEKO 371: 54 x 50 x 26 mm
- TEKO 372: 83 x 50 x 26 mm
- TEKO 373: 106 x 50 x 26 mm
(the inner width of these is only 47 mm!)
but also for example:
- TEKO 392: 83 x 68 x 28 mm
- TEKO 393: 122 x 68 x 28 mm
I used the TEKO 372, because to test the effects of better magnetig shielding from his steel sheet, and as a compact alternative to the Hammond 1590B. But for a standalone, maybe TEKO 393 is better, not only to have space for the pomona's, but also to use the pcbs as they are to save your extra work and service.
So, actually, an extra slim pcb is only necessary, if one plan to put a TEKO 371 or 372 without binding posts or banana jacks inside an other housing for additional magnetic shielding.
Thanks for your good work
