If i do the calculation, i am getting -11,8 mV, not -117 mV.
R35/R36 = 10K/40K = 1/4 Measured: 1,76 V/7,07 V = 0,249
R31/R34=5K/750K=1/150. Checked R34 Label. In-circuit 190 KOhm.
7.07 V / 600 = 11,8 mV
Where is the error?
Regards, Dieter
Edit:
Just measured some timings. At 0 V input the 7.07 V reference pulses to the integrator are mainly 17.635 usec or 15.485 usec at a fixed rate of 10 msec (100 Hz). On average this is about 1/600. CD4046 PLL output is measured as 3.684 MHz. The screen dump includes the histogram. The scope counts how often each pulse length happens. It does not look like a gaussian (noise), but there are two peaks.
