Branadic hardly a sales person
![DMM :-DMM](https://www.eevblog.com/forum/Smileys/default/smiliey_dmm.gif)
. And thread started for PSU design talk and sharing results, not for fixing particular altered and possibly damaged LTZ ref.
Before going EMI rabbit hole it is better to apply requirements expected from voltage reference application. If its going to be measured by floating DVM and null-meters against other references then major required feature of PSU is low leakages and common rejection to avoid ground loops. If reference is used as a part of bigger system (like A9 3458A module) it have different requirements for PSU. Above shown A9 module is very sensitive for pickup and grounding. It is essentially useless as transfer reference on ppm level. Just turning common LED lamp with crappy SMPS will ruin your A9 output stability and noise. No matter if powered by nude virgin custom ppmium transformer or fire breathing lithium pack. And thats offtopic here, we already have excellent RFI\EMI test thread
right here.
I really don't understand View[]Finder's resistance to make own thread named "Experiments with DMMs and references" and post all stuff there, people will be much happier to help and suggest things when it's all in one dedicated spot, instead of guessworking thru 5 different hijacked threads on what is going in. Threads creation does not require payment or anything
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
PPMs also nothing to do with external data, that is completely wrong, just like saying percents are anything to do with calibrations. It's just a convenient tool to do the opposite - remove absolute values from measurands and outline the deviation of one set with arbitrary selected point(s) against another.
to find a way to have a $200 standard perform as well as a $2,000 one
$200 standard will stay such, no matter what magical power is used to power it. Noise is
least of the problems in voltage references, compared to much harder issues like stability, temperature/humidity/pressure dependence, jumps and stress factors, robustness during transport, etc.
