Should be easy enough? Yet I've had trouble with the screws. So I looked up "GPIB connector" on Wikipedia to see what thread is used, and reference #21 took me to a Hewlett-Packard document that states on page 28 that:
Metric threads (ISO M3.9 x 0.6 type) are specified. Metric fasteners are typically coloured black. Some existing cables use English threads (6-32UNK). They are coloured silver. DO NOT ATTEMPT TO MATE ENGLISH AND METRIC FASTENERS, as damage to hardware may result.
I think you mean reference #20, not #21. But it’s much smarter to just post a link to the reference itself, since wiki articles change over time.
http://bitsavers.org/pdf/hp/hpib/TutorialDescrOfHPIB.pdfAnd here’s a different edition of the same document, with grayscale images, etc:
https://www.hpmemoryproject.org/an/pdf/hp-ib_tutorial_1980.pdfAh ha! Now I know why I had trouble. Some of my cables have black fasteners, some silver. But it gets worse, far worse. Firstly, there is no such thing as M3.9 x 0.6, and M3.9 would be much bigger than any GPIB screw I've seen. I think HP meant M3.5 x 0.6 which is commonly used for electrical stuff.
There seems to be wide agreement that the screw is M3.5x0.6, which does suggest that M3.9x0.6 is a typo. (Probably confused with M3.9 self-tapping screws.)
FYI, M3.5 is no longer widely used, and in fact is very hard to find now. They’re only encountered in old stuff. Fastener manufacturers have largely removed them from their stock item catalogs.
Next, there is no such thing as 6-32UNK. But there is such a thing as #6-32 UNC.
Ehhhh, the statement I bolded is incorrect.
Just a little info about the American thread types:
The primary standard is called UN (unified national thread). UNC (UN coarse) and UNF (UN fine) are tables that define particular thread sizes, but because the thread pitch is given in the thread size, a given size can only fit into one of those tables. So a #6-32 UN thread is always UNC, for example, because the #6 UNF thread is #6-40. The thread standard itself is simply “UN”.
UNJ, UNR, and UNK, on the other hand, are not tables of UN thread sizes, but separate standards with slightly different thread geometry to improve performance. UNR specifies that the external thread must have a rounded root, and UNK was just UNR with extra measurements made mandatory. UNJ specifies modified internal and external thread geometry for the highest performance. UNK, apparently, was “obsoleted in 1979” according to the first source below, which has a comprehensive overview:
https://www.ring-plug-thread-gages.com/ti-UNR-vs-UN.htm (this website has a few other interesting pages covering minutiae of the UN thread family and seemingly every other thread family in existence)
https://www.ultrasonic-resonators.org/misc/references/articles/Kanter__'Taking_the_Mystery_Out_of_Screw_Thread_Forms'.pdfhttps://jlmetrology.com/screw.htmlAnyhow, this means that a male #6-32 screw in the UNK standard would technically be, for example, a 6-32UNKC, and it would mate with a #6-32UNC or #6-32UNJC female thread.
While UNK screws are understandably impossible to find, since they’ve been obsolete for 45 years, UNR screws appear to be readily available, including #6-32UNRC.
It could be a typo in HP’s documentation and that they intended UNC, but chances are it’s not, and they were simply specifying the very best variant at the time, in which case they actually should have written UNKC or UNRC.
Other HP documentation, like this one
http://www.bitsavers.org/pdf/hp/98xx/98034-90000_hpibIntf_May79.pdf describe the old units as using “National Coarse” threads, which would be UNC, and thus UN. But that’d be the same fundamental dimensions as UNK.
It's an American thread, by the way. The #6 refers to diameter, the 32 its pitch in TPI. A #6-32 screw is too small for the GPIB screws, and the pitch is too coarse. But #5-40 seems to match GPIB screws both for diameter and pitch. And guess what, 40TPI corresponds to a metric pitch of 0.635mm, and a #5 screw is 1/8" diameter, or 3.175mm. So M3.5 x 0.6 is sufficiently similar to #5-40 UNC that you could force one into the other and cause damage.
I ran an M3.5 x 0.6 tap into the heads of my (black) screws and varying amounts of swarf came out. They should have been M3.5, but I suspect they were #5-40 UNC (described elsewhere as an obsolete thread, but apparently alive and kicking). I've ordered a #5-40 UNC tap and die set.
To sum up: Don't believe that HP document. Any GPIB screw you see is probably #5-40, even if it's black. But it might be M3.5 x 0.6. No wonder we have trouble!
The mounting side of the GPIB connector screw is not specified, but apparently in many, it was 6-32. (See e.g.
here.) So it’s not inconceivable that early connectors really did use #6-32 for the mating-side screw, too.
It is
highly unlikely to be a #5-40 thread, as the odd-numbered screw sizes (like odd-numbered AWG wire sizes) are exceedingly rare in the wild. It’s much more likely to be M3.5 like the world in general agrees they used, or #6-32 (regardless of whether UNC, UNKC, or UNRC).
But it will be interesting to see what you find once you get your #5-40 tap and die set!
