Hi all electronics superstars!
I have been reading though lots of info about LTZ1000. There are numerous PCBs used.
I plan to build a LTZ1000 reference. Of main importance is the 7V direct output. If the circuit also can output 10V thats not really needed but could be nice too.
Intend use is as a learning project, to see how multimeters drift over time and look into low noise measurement set-ups. Something with a balance that score reasonably well in all areas of low noise, low temperature coefficient and low long term drift.
Targeted budget around 200 to 300 USD.
Which of all PCBs out there would you recommend to make the build on? Preferably a PCB that can either be ordered ready made or for which gerber files can be found.
