It was in the work bin and probably from an office that was cleaned out. Why and when it was removed from its casing I will never know.
Took another reading after letting it settle overnight in the lab, (21 deg C), and it seems to be stable around 1.018560 V. (given my.. umm.. excellent low thermal connections
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
The date is 26/04/1960 so not bad for a 56 year old (older than me
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
). I cant recall seeing many of these things in my time as they were quickly replaced with the cropico and other electronic standards.
Even the cropico's were long ago retired and tossed
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
, (see my other thread!) . Lets just say there are 'suitable' alternatives available.
POSTSCRIPT :
While I was having a quick look around to see if any other cells found their way to the back of a cupborad somewhere I did find a colleaque/collector of fine antiquity like me had a duff CAMBRIDGE INST. cell still in a case and kindly offerred the casing for the MUIRHEAD.
The case is two cylinders separated with insulating wool for thermal lag, and usually the cell sits in oil too (I wont bother with the oil though).
A hole in the top cap is for a mercury thermometer.
So after a little bit of fitting see the pics of its new home. Now this old weston cell will stay in my lab at least till I'm gone anyway
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Will measure after the weekend allowing it to settle again after all the handling.
