Author Topic: Old fashioned zener 10V reference  (Read 41352 times)
Offline Mickle T.
  • Country: ru
Re: Old fashioned zener 10V reference
« Reply #50 on: February 14, 2024, 06:29:25 am »
Simple low noise voltage reference with 4 zeners. TC ~1 ppm/°C, 0.009 uV/V RMS noise (0.1-10 Hz).
Update 1: Fixed a stupid error in the circuit diagram
« Last Edit: February 15, 2024, 11:47:33 am by Mickle T. »
The following users thanked this post: branadic, Dr. Frank, Andreas, Rax, RoGeorge, guenthert, 2N3055, ch_scr, Kosmic, miro123, Victorman222
Offline EC8010
« Reply #51 on: February 14, 2024, 02:21:34 pm »
I'm guessing that 3C108C is akin to 1N829? An Internet search didn't find them.
Offline Mickle T.
  • Country: ru
« Reply #52 on: February 14, 2024, 02:28:01 pm »
This is a typical example of temperature-compensated zener diodes. It is difficult for search engines to find, since the letter “C” is written in Cyrillic.
https://www.optron.ru/catalog/stabilitronyi/2s108s/
The following users thanked this post: EC8010, ivo
Online mawyatt
« Reply #53 on: February 14, 2024, 06:36:04 pm »
Watch out as VD1 (12V) is across the 15V power input!!!
Best,
~Wyatt Labs by Mike~
The following users thanked this post: Mickle T.
Offline Vtile
  • Ingineer
« Reply #54 on: February 15, 2024, 03:32:05 am »
Nifty design.
« Last Edit: February 15, 2024, 05:12:00 pm by Vtile »
Online Andreas
« Reply #55 on: February 15, 2024, 06:57:09 am »
Hello,
you obviously measure the 6.5V output with relative high impedance ~130 Ohms.
So how is the input impedance of your LNA measurement amplifier?
And did you correct for the "voltage divider"?
with best regards
Andreas
Offline Mickle T.
  • Country: ru
« Reply #56 on: February 15, 2024, 07:07:00 am »
You are absolutely right. The internal resistance of the source is 134 Ohms. At the same time, the minimum input impedance of the amplifier is limited by a differentiating chain resistor of 3.3 kOhm. Therefore, noise amplitude correction was introduced.
The following users thanked this post: Andreas
Online iMo
  • Country: bj
« Reply #57 on: February 15, 2024, 07:35:15 am »
In my $5 noise indicator project I reported aprox 2uVpp in 0.1-10Hz measured on a junkbox diy 6.9V zener @3.6mA.
2uV/2/6.6/6.9=0.022uV/V RMS in my case of 4 in parallel. His is 2x lower with special diodes @ 2x higher current, better construction and better LNA, so it fits well..
PS: here..
« Last Edit: February 15, 2024, 07:54:03 am by iMo »
Offline Victorman222
  • Country: ua
« Reply #58 on: March 15, 2024, 11:08:46 pm »
I wanted to measure some diodes for zero TC current and needed to make a reference to do relative measurement. It didn't need to be anything fancy but at the same time i wanted to try to make a hermetic box for it. First try was with some steel that solders nicely, but it didn't turn out hermetic (maybe instead could repurpose something like hermetic paper capacitor case). Then i remembered that i have some hybrid IC cases, quickly drew the most basic schematic, designed and etched PCB. The performance will probably be somewhere between good and bad...
The following users thanked this post: Mickle T., EC8010
Online iMo
  • Country: bj
« Reply #59 on: March 16, 2024, 05:35:30 pm »
After you test your prototype - for the final version I would cleanup the pcb carefully, also - when you are keen on filing the resistors - try to setup the divider from a larger value and a small value, and then do file the small value only..  :)
The following users thanked this post: Victorman222
