Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Metrology
2465B CTT calibration question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 2465B CTT calibration question (Read 1534 times)
mmaseda
Contributor
Country:
on:
January 01, 2018, 03:26:42 am »
I need to run the CTT calibration routine to remove an error message but I don’t have pulse and time-mark generators. I have several function generators, signal generators, and 1MHz and 10 MHz TCXO. Can any of these be used to run the routine?
Last Edit: January 04, 2018, 12:15:45 pm by mmaseda
Logged
SoundTech-LG
Frequent Contributor
Country:
Re: 2465B CTT calibration question
Reply #1 on:
January 03, 2018, 09:22:14 pm »
I really suggest you get the recommended equipment to run the cal. I tried using other equipment with very limited success. Once I got the right gear, it was pretty easy.
Logged
mmaseda
Contributor
Country:
Reply #2 on:
January 04, 2018, 03:58:39 pm »
Thanks to those that replied. I was able to perform the calibration by just using a 1MHz 1v peak to peak signal from a TXCO.
Logged
SoundTech-LG
Country:
Reply #3 on:
January 04, 2018, 09:56:15 pm »
Making some sort of adjustment to get it to pass power on testing is certainly possible using a 10mHz
TCXO output signal, performing a critical calibration is certainly another thing altogether. I doubt Tek would suggest the equipment listed unless there was a pretty good reason to not follow their suggestion. If it passes the power on test though, hey, maybe you got lucky.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Metrology
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
