@bdunham7
Just tested that.. At first it read 000.0, then after a few seconds -000.1 and then after some more seconds it stabilized at -000.2 and it's staying there.
--UPDATE-- I just read the official accuracy specs and it's only got a 600V scale for DC, no other scale. For DCV the accuracy is 0.5% + 5 digits, so that's half a volt right there!
So I guess it's within spec after all. This is a clamp meter geared towards power measurements, I bought it because the electricity network is bugging me to upgrade my subscription to 10KVA instead of 6.9KVA. They say my usage excceded my plan, which is a blatant lie, I only have a 4.5KW water pump... I suspect it's the pump motor start surge current that's triggering the smart meter, the old one was fine for 10 years GGRRRRRRr
... I'll probably make a post about that later on...
Anyway, still interested to know if the error is correctable
Not that I'll probably do anything about it....
