Hi ZhuraYuk,
It seems like the software isn't required you just need the password. I've tried it on two units and helped a couple other people with it and it's worked for all of them. Keep in mind, you can't unlock options that aren't installed. These options are separate boards that are installed at the factory. Here are the steps and password:
- Once booted up press the "Mode" button
- Select "CALIB"
- Enter the password - 2357
- Select "FACTORY USE ONLY" at the top right corner
- Enter the password - D1TR4N
- Select "DEFINE OPTIONS"
- Select the installed options
I hope this helps!
