Some time ago, I disassembled a faulty TKZD13/D (it was too noisy if i recall correctly). Inside, I found three Zener diodes (likely 2x KZ260/6V8 and 1x KZ260/7V5 - its real Zener voltage was 7.1V, so you got approx. 8.5V in total: 2x0.7V+7.1V) and one wire wound resistor (see attached schematic for the internal connection). The diodes were sealed by some kind of epoxy resin. The resistor values varied between samples (had four of them). I measured following values: 1.48 kOhm, 2.10 kOhm, 4.22 kOhm, and the last one was open (> 20 MOhm).
I was surprised they used KZ260 which is a general purpose Zener diode, nothing fancy (see attached datasheet). I suppose they had to age references and select the best ones with low long-term drift.
