Author Topic: u-blox M8T firmware FW 3.01 TIM 1.10  (Read 6338 times)
Offline wgoeoTopic starter
« on: July 05, 2019, 10:02:59 am »
I haven't seen this out there so here you go.
MD5 is 9a999e9cf84f0b3a0a7ed0146d20e5cc as indicated in filename in the PDF.
Rename .hex to .bin
The following users thanked this post: istamov, thinkfat, Illusionist
Offline Illusionist
  • Why is the rum gone?
Re: u-blox M8T firmware FW 3.01 TIM 1.10
« Reply #1 on: July 05, 2019, 05:59:19 pm »
Thank you, I've been looking for this  :-+
I must admit I was wary of flashing an image from a stranger on the 'net though  :scared:
The MD5 matched the online docs from ublox though, so I gave it a shot on (cue Gollum) my precious only Neo-M8T, version 0-00. I can confirm it works.
For those who try and wonder where the FIF file is that the updater wants, it's in the ublox u-centre installation. Just browse to there and find the flash xml file.
ETA: My GPSDO-to-be also wishes to thank you...
« Last Edit: July 05, 2019, 06:11:43 pm by Illusionist »
Agilent 34410A, GW Instek 8251A, Thurlby 1905A, Siglent DS1104X-E(unlocked), SDG1032X(unlocked), Micsig DP10013 MX, LeCroy PP008 500MHz Probes, Fluke 179
Offline charly724
« Reply #2 on: February 09, 2020, 11:42:57 am »
Many Thanks...
works also good for me. Update is very easy with the u-center via USB
Offline rplabs
  • Country: at
« Reply #3 on: August 23, 2023, 12:35:25 pm »
I saw it in some u-Blox PDF files that there is a new release for TIM but FW revision stays the same.
Flash FW 3.01 TIM 1.11
There is also some documentation for M8 where it says FW 3.5x is also available. It is not clear if M8T is also covered by this release...
Does anyone have more details about which models have FW 3.5x or what is TIM 1.11 ?
