OK JS and Kleinstein, I humbly stand corrected!
I obviously made a mistake with my PPM calculation. I was influenced by the trim construction that Fluke used in the 720 on the first decades.
OK, another little step closer, thank you for taking the time to point this out.
Kleinstein, or anybody, I could only find one more candidate, the Vishay OSOP series with 10 resistors that seem to have the right specifications. Could you please point me in the right direction for a suitable resistor network with a low TC that packs 12 resistors with adequate precision?
After thinking some more about the practicality of resistor matching for the second decade, it dawned on me that it is quite impossible, or as a minimum really messy, to combine resistors from networks in other decades. With a matching requirement of +/-0,037%, that is not easy to do in any case. If a PCB layout is ever constructed, it will be much easier to bite the bullet and spend another 10-15 Euro's on trimpots and also make the second decade with trimmers. The third decade needs a matching of +/-0.37% and that can be met by using 0.1% individual resistors or a network with that precision, or also use trimmers.
How that will turn out is largely depending on the available resistor values and precision for the networks. The AORN, NOMCA and the OSOP series look good, but the first two are limited in the available resistor values, and pack only 4, 7 or 8 resistors. The OSOP supports 1K, 2K and 10K values with 10 resistors in a package.
For the first decade, I have found with my current KVD prototype, that the resistors should match the 10K value per resistor pretty well. Unless I'm wrong with that, this means that the first decade needs to have a small resistor of 100 Ohm in series with the 10K, in order to adjust it around the 10K value with a shunt of a 1M resistor and a 25K trimpot, following JD's and Kleinstein's suggestions. With the trimpot at 50%, the result is 10K0, and there is a +/- 1.2 Ohm trim possible. That span will most likely be too much for a single turn pot in order to get a match within +/-0,0037% because for 10K the span is only +/-0,37 Ohm. Values can still change to a tighter span, but that depends on the specifications of the available networks.
Thank you all in advance for taking the time to contribute!
