I have a measurement I am trying to take involving small (mV) signals that are super-imposed with offsets that are essentially step-functions (600mV max).
The step-functions have a width of 50uSec up to 10's of mSec. The small mV signals are slow in time, sub 1kHz. Using a 24-bit sigma-delta with low BW means I get great resolution on the small signal, but when I add the offsets to the mix, they cause giant exponential decays.
Using a faster ADC, 2MHz 24-bit SAR, I can remove the step in DSP, decimate down. However, I can't get enough resolution through decimation. I need to maximize BW before removing samples, or I end up with a lot of samples to throw out while things settle, and I can lose significant portions of my signal-of-interest.
In a perfect world, I could remove the step-functions perfectly, gain-up the smaller signal, and just use a regular 16-bit ADC.
Can a DAC be used to force a signal within the dynamic range of my ADC? Are there implications for SNR and resolution that I'm not thinking of?
