How would you go about realizing the null detector with an existing core as this needs a very special construction technique?
It should be possible to build a DCC-bridge by rewinding an existing DCC transducer (with already present zero flux core) like the Ultrastabs/Danfysik ones available used on ebay. Ive never continued this project though.
Happy to see if i can infect someone with the idea, who then realizes it
