Author Topic: LTC6655B long term drift  (Read 13108 times)
Offline BravoV
  • +++ ATH1
Re: LTC6655B long term drift
« Reply #50 on: May 18, 2019, 07:41:51 pm »
Watch out for humidity change too.
Offline alex-shTopic starter
« Reply #51 on: May 18, 2019, 07:47:48 pm »
The MSOP8 package is worse than the LS8 package.
Very much true.
In fact I did not realise that MSOP8 would be that bad in the beginning.
I am testing now LT1236LS8 with a proper pcb cut-outs.
« Last Edit: May 18, 2019, 07:50:31 pm by alex-sh »
« Reply #52 on: May 18, 2019, 07:49:25 pm »
This I can hardly control.
I do not even have a lab with const temp / hum.
Offline BravoV
  • +++ ATH1
« Reply #53 on: May 18, 2019, 07:54:35 pm »
Although I haven't try it my self, may be one day, as curious what if the chip is sealed inside a glass tube. Of course you need to extend the pins longer like through hole components.
Just an example ampoule glass sealing, google for your self, random youtube video to give your the idea.
https://youtu.be/GEmINGq8HDQ
Offline Gyro
« Reply #54 on: May 18, 2019, 08:19:47 pm »
The problem might be getting sufficiently hermetic sealing of the leadout wires to the glass - wetting, different thermal coefficients of expansion etc.
You'd be better with a small soldered copper sheet box construction with ready made hermetic feedthroughs, eg. https://www.ebay.co.uk/sch/i.html?_odkw=hermetic+feedthrough&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=glass+hermetic+feedthrough&_sacat=0
You can also then pass normal copper wires through them to minimise thermocouple effects.
« Last Edit: May 18, 2019, 08:22:39 pm by Gyro »
Best Regards, Chris
