Hi TiN and thanks for your reply
I actually read your article about the EDC MV106 quite some time ago. I guess that is the reasone that somewhere in my mind there was the idea that it shouldn't be to complicated, looking at the schematic it looks like an easy concept.
Sadly I don't have that many details about the decades besides what I already wrote: They are Hartmann & Braun "Technischer Dekadenwiderstand" for DC to 10kHz, accuracy is 1% for 0.1R to 1R and 0.1% for values above 1R.
They consist of 10 identical wirewound resistors on ceramic bobbins and a nice clunky 11 position switch. I have the values 0.1 (so 1R max) to 100k (so 1M max) available with 1k and 10R being available twice.
The only other thing that I can find in regards to accuracy is the number two in a star like in the accuracy class of analog panelmeters.
They are simmilar to those:
https://www.ebay.de/itm/143221153191?ul_noapp=true Edit: I just noticed that the seller posted a photo of a "datasheet" of those specific decades. If we assume that the resistors are as similar as the specs of the decades then they should be made from "Aurotan", which is actually a brand name for Manganin. So that woule mean a temperature drift of 10ppm per kelvin.
Regarding my personal goals in accuracy and the available budget:
Surely better is always... well, better. But since I don't own any too fancy lab equipment (yet.. the TEA virus is strong.) and my keithley 199 is the most precise thing I have. It would be cool to be able to build something that could potentially calibrate the DMM, but it is not neccessary to get too fancy. Let me state it like this: A LTZ1000 shouldn't be needed here
It should be quite stable over time and temperature but I don't want to get to fancy and basically scrap the decades and buy a whole bunch new resistors. If those wirewound resistors prove to be not good enough - well, then they aren't and I have to work with what I have and reduce the spec. Price wise I am not that restricted, however, everything should be somehow reasonable.
