Author Topic: UV lines of mercury spectra  (Read 2206 times)
Offline PhysikfanTopic starter
« on: January 28, 2018, 12:23:27 am »
The spectra are photos of Hg spectra with increasing exposure time from top to bottom, light source is a Hg high-pressure lamp, the entrance slit is imaged with a quartz lens via a reflection grating on a screen, to detect the UV lines, the right part of an ultraviolet screen:
Only in the first two spectra do the colors correspond to the visual impression with unarmed eyes.
The blue line on the far left in the last spectrum is a ghost.
Further experiments with quartz glass prism and zinc sulphide screen are in preparation.
« Last Edit: February 04, 2018, 12:12:42 pm by Physikfan »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: UV lines of mercury spectra
« Reply #1 on: January 28, 2018, 02:34:56 am »
This isn't accurate, right? -- Because UV+vis covers more than an octave bandwidth, so the green lines are second order vis lines, no?
Seven Transistor Labs, LLC
Offline LaserSteve
« Reply #2 on: January 28, 2018, 02:56:42 am »
He's projecting on a Green  Phosphor.. That looks exactly correct..
see:
https://physics.nist.gov/PhysRefData/Handbook/Tables/mercurytable2.htm
Steve
"What the devil kind of Engineer are thou, that canst not slay a hedgehog with your naked arse?"
I am an unsullied member of the "Watched"
Offline cdev
« Reply #3 on: January 28, 2018, 04:00:18 am »
see image.
The filter is a dichroic filter originally meant for scientific instruments. I've had it for ages. Thats my monitor here, right now.
The color output of an LCD with a florescent backlight.
You can clearly see the lines with all sorts of light sources.
« Last Edit: January 28, 2018, 04:02:24 am by cdev »
Offline John Heath
  • 2B or not 2B
« Reply #4 on: January 30, 2018, 03:27:32 pm »
It should look like this with a cool thumb print of the two very close lines at 3650 3653. I would venture a guess that the two greens in the third brightest photo is the tell tail thumb print 3650 and 3653.
