Author Topic: I bought the very Last Symmetricom SA.22C in the shop!  (Read 19249 times)
Offline Smile2016
Re: I bought the very Last Symmetricom SA.22C in the shop!
« Reply #50 on: July 12, 2024, 12:17:49 am »
Z04 are likely these: nc7sz04 "TinyLogic UHS Inverter"
that's the one + datecode
Offline Smile2016
« Reply #51 on: August 26, 2024, 04:37:10 pm »
Is it possible to change the factory reference crystal on the unit?
I am planning to buy a unit that doesn't output 10Mhz it only ouput 9.8304MHz from factory.
How to check reference crystal frequency? my unit shows 60.00MHz at startup and 39.38MHz if I use "i" command .
SA22C by Symmetricom, Inc., Copyright 2006
SA22 Version 6.01C of 7/2006; Loader Version 3
Mode CN01 Flag 0000 [D04D]ok
Unit serial code is xxxxx-h, current tuning state is 6
Crystal: 60000000hz, ACMOS: 10000000.0hz, Sine: 10000000.0hz
r>
and with command i:
r>i
Mode CN01 Flag 0004
Unit serial code is xxxx-h, current tuning state is 6
Crystal: 3938700hz, ACMOS: 989680.00000000hz, Sine:989680.00000000hz
opened one unit , cannot directly access a physical crystal that could be exchanged anyways...
« Last Edit: August 26, 2024, 04:39:21 pm by Smile2016 »
