Been working with a Die Cast aluminum Bud Box where the KX reference and buffer/follower boards will reside. Decided to ovenize it, set at a reasonable 35 deg C (one of the reasons I decided on using higher temp 13K for the heater). The oven control circuit is working very well, and seems to hold the internal air temp to well within 0.1 deg C. Still playing with the feedback gain and placement of the thermister for best performance, its a very slow process. Meanwhile the KX board cooks away with 1 cent metal film resistors and has not budged, Ill have a 1000 hours on the can by the time the Vishay parts arrive. My plan is to build everything in a small portable enclosure with 10AH of battery power. Photos and test results to come.
Used some closet shelf angle brackets to make a nice mount for the KX board;
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/BBC6E463-0BA3-4479-A61A-3AF0D9F9573E.jpg)
Initial testing to see how much power would be needed to heat the box;
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/8DABDDC7-D6D3-4107-8531-EF5D1546C5B6.jpg)
Decided on 2x 25 Ohm 10 watt resistors in series for a 50 Ohm heater load;
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/40C478E9-E9E3-4277-B214-DC415A9486B8.jpg)
This will heat the box from 20 deg C to 35 deg C in about 20 min with 20 volts at 0.4 amps (8 watts)
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/4B18374A-832A-4DE3-9467-9AAF7EF406F1.jpg)
Playing with the feedback gain;
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/C6AEFC47-EF5B-4998-9F6E-3BF82B6CA1D6.jpg)
Still very much in proto stage, but its coming along nicely;
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/46B29F69-C9DF-4527-A3F3-65B906AA513D.jpg)
Edit, some temp ramp and stability graphs;
From 20 deg C its within half a deg of 35 in about 30 min.
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/F0D0A54C-700B-4949-84D9-8FD224D5F669.jpg)
Zoomed in, 0.5 deg FS, it holds within 0.1 dec C. I'm at the limits of my temp measuring ability, not sure I can tune anymore ripple out, but I'm happy with this.
![](http://i241.photobucket.com/albums/ff146/wsmc551/Elecronics/D1B59403-8DBE-42F1-83B2-E8793756BA46.jpg)
