Author Topic: Measuring Stuff Digitally Without an A to D Converter  (Read 3417 times)
Offline fourfathom
Re: Measuring Stuff Digitally Without an A to D Converter
« Reply #25 on: December 22, 2023, 06:39:00 pm »
Siglent attempts to detect rotational position with some of their test equipment without an ADC.
I suppose using a gray-coded optical or electrical-contact disc?  Or just a quadrature coded disc for rotation direction and speed but not absolute position.  No D-A there, just multiple on/off sensors (still digital, though).
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
The following users thanked this post: Richard_S
Offline julian1
« Reply #26 on: December 23, 2023, 12:43:39 am »
I want to say a pendulum clock/or write-watch balance, where the timing of the swinging arm/mechanism is gated and counted by ratchet gears, to provide a count that measures analog time.
Although maybe it is an example of a mechanical ADC.
Offline David Hess
  • DavidH
« Reply #27 on: December 23, 2023, 02:15:35 am »
A voltage to frequency converter is another kind of A/D converter.
It is if you add a counter, but the output is pulse density modulation and can be used directly.  Run the output into a charge pump along with another voltage, and you have a high accuracy voltage multiplier.
Analog sampling oscilloscopes draw a series of dots on the screen, but they are not digital either and produce a 2D pulse density modulated image.
I do not remember what it is called, but there is another converter similar to a voltage-to-frequency converter which produces two outputs, and the value is the ratio between the two frequencies rather than the absolute frequency.  Some universal frequency counters have an A/B mode which can read their output directly.  Maybe that is the reason A/B mode exists on old frequency counters?
Offline Nominal Animal
« Reply #28 on: December 23, 2023, 02:37:30 am »
Many old analog joysticks used rheostats AKA variable potentiometers, a capacitor, and a comparator; measuring the delay between the supply side falling to zero, to the RC-filtered signal falling below a fixed threshold.  Unlike most other methods, this is not analog to digital conversion, because the variable analog resistance is converted to a variable analog delay!
The actual conversion to digital was usually done by providing a fixed-duration pulse to the rheostat, and counting the period of output being high in clock cycles.
I believe astronomers counted photons for a while already.
In optimal conditions, the human eye is sensitive to individual photons.  Our brain does some filtering, so a few (three to ten) photons within a short interval (0.1 seconds) are needed for the perception to form.
Or if we put a capacitor on the gain node, the current difference gives a dV/dt, which we can measure with a clock and counter, and, same thing: the instant the voltage crosses the reference threshold, occurs at some instant between two edges of the clock; the analog time is bounded.
Yup, very similar to how the old-timey analog joysticks I mentioned above worked.  The time interval is still analog; measuring the interval with a digital clock is the actual analog-to-digital conversion.
« Last Edit: December 23, 2023, 02:41:39 am by Nominal Animal »
« Reply #29 on: December 23, 2023, 04:03:08 am »
In many particle physics sensors individual separate events (photons, particles, collisions) with a known minimum interval in between, tend to be easy to handle.  Many such sensors have a dead time after each individual event.  It is when you want to measure both event counts and individual event properties (wavelength or energy, typically), and want/need to detect concurrent events, that things become hairy.
For this reason, particle colliders don't even try to measure the collision result particles directly, and instead use many layers of detectors measuring the dissipation of energy, often with a heavy electromagnetic field so that the actual trajectory reveals further information on charged particles.  Indeed, each collision event is more like a tree, with each branching point being a subsequent collision or decay event; with the entire tree of events and (intermediate) particle properties forming a system of fuzzy equations –– fuzzy in the QM sense! –– that is solved as a system, to identify the original collision result particles (even if they themselves left no directly measurable traces in the detectors, for example due to being too short-lived, with the closest layer of detectors being too far from the collision site).
When measuring e.g. radiation spectrum, using a filter that only allows a specific energy (wavelength) at a time, makes things easier.  Then, the energy of each photon is known, and a relatively cheap CCD element can count individual events with very short dead times.  Adjusting the sensor distance from the source affects the solid angle the sensor covers with respect to the sample, so the event intensity can be adjusted by adjusting the sensor distance.
Calculating the actual activity of radioactive samples using such equipment is where I personally first used elliptic integrals in anger.  (Calculating the exact effective solid angle of the detector with respect to an uniform-activity sample volume yields elliptic integrals.)  I quickly found out that using a suitable program (with a sufficiently random pseudo-random number generator) to simulate a radioactive sample emitting individual photons is not only faster (in terms of amount of human work needed; not in raw computation time needed), but also easily visualized and verified.  Even a cheap laptop can simulate a few billion photons with planar, conical, cylindrical, and spherical surfaces and filters, within a few seconds to a couple of minutes, so getting a precise enough result with tight enough error boundaries, with sufficient margins, does not take long at all.  It is particularly useful when the detector distance from the sample and detector geometry is such that not all points on the sensor surface are directly "visible" from all points within the radioactive sample.
I did end up calculating it both ways, with the results (effective solid angle of the sensor) agreeing with each other, of course.
Which, put another way: digital is a strict subset of analog where we define thresholds for '1' and '0' (or any other values), but if we dial those thresholds down into the noise floor, it doesn't really matter, does it, we're counting statistics of bits equally as well as analog spectra down there.  Quantum is a superset of analog, I suppose is the point then. :D
I prefer digital:analog ≃ discrete:continuous, because it is more useful when building specific domain knowledge on top.  In particular, "to convert to digital" ≃ "discretize".
In the example of using a capacitor discharge to measure a current, or an RC lowpass filter to measure resistance, by converting the current or resistance to a time interval (still in the analog domain), the conversion to digital occurs when the measurement is discretized.
Now, in quantum mechanics and related physics fields, most things are quantized.  Thing is, that does not mean they are also necessarily discretized, even though the observables related to the quantized properties often have discrete values.
Very often the quantized properties can be described using complex numbers.  Then, the magnitude, or absolute value, is an integer multiple of some real positive value ("one quantum"), but the direction in the complex plane may vary.  This is also why summing two or more such quantized values is rarely equal to the sum of their magnitudes.
In the double-slit experiment, where emitting individual photons or electrons (all with the same energy) through a double slit (with suitable size and slit separation) yields an interference pattern, the particle location and trajectory is described using a quantum wave function.  The double slit acts like a filter, so that the resulting wavefunction is a sum of two wavefunctions.  Because these wavefunctions can be described in complex number form, the above note about summing applies, and the resulting wavefunction has the same shape if we had two particles at the same time, one particle through each slit, interfering with each other; just with lower amplitude. Because of how the amplitude of wave functions is defined, the probability distribution of where the particle will hit the display surface is the square (and not just magnitude) of the wave function at the display surface.
In a real sense, the double slit quantizes the location of the particle.  It does not, however, mean that the particle will pass through one or the other slit; it does not discretize the path or trajectory.  In fact, if you do something that causes each particle to pass through just one of the slits, for example measuring which one it passed through, you lose the interference pattern, and just get a sum of two gaussian distributions.  This is because then the resulting wave function is no longer a sum of two wave functions; it is always one of two possible wave functions instead.
If you grok that, you grok the core idea in quantum mechanics, I believe.  Thus, I don't think considering "quantum" a superset of "analog" is useful at all.
The following users thanked this post: T3sl4co1l, alm, arcnet, Richard_S
Offline Richard_STopic starter
« Reply #30 on: December 23, 2023, 05:14:34 am »
I have a ruler.
Ah ha, the original!
Not electrical but then say a modern electronic vernier which uses magnetic pulse counting would be exactly that. I once had the privilege of a visit and tour around a factory where they made such devices.
Offline tggzzz
« Reply #31 on: December 23, 2023, 08:51:55 am »
Yes, particularly since new scopes do that in two dimensions, some older ones in one dimension, and the original scopes in neither dimension. The middle variant seems hard for youngsters to believe.
Offline TUMEMBER
« Reply #32 on: December 23, 2023, 12:38:17 pm »
quantum theory of everything
each of these particles is the same in terms of shape, but is variable "in terms of content" and only "randomly" assembled gives the correct image (result). How much work can be done by an ordinary brain.
Offline fourfathom
« Reply #33 on: December 23, 2023, 07:28:57 pm »
Analog to timing joystick: Back in the mid-1970's I made a "Pong" game equivalent, using an oscilloscope in X/Y mode (rather than using a TV modulator).  Each player-side used the joystick voltage (single axis, it just moved the paddles up and down) into a comparator, with a ramp on the other input.  This, and one-shots (another analog-controlled digital device) created the on-screen graphics.  I don't remember *any* of the details, but doubt if I did anything for retrace-blanking, etc.  My buddies and I did this when we were supposed to be testing and troubleshooting stuff.
The following users thanked this post: Nominal Animal, arcnet
