Quote from: USMC_Spike on February 21, 2017, 06:05:29 am...So I'm in limbo until I can find a good working affordable display.Hoping that is the only problem I'll find on a former working unit.If you have any ideas....I'm all ears.SpikeUSMC_Spike; Have you tried running the unit remotely over the serial port? You could then at least verify operation. adapt-improvise-and-overcome Also I've heard UPS is notorious for flatly rejecting initial clams. It not too much time has elapsed you may want to challenge their response.
Nuts.No GPIB gear here Thanks for the clarification though.
