Author Topic: HX711 scale amplifier where to buy / experience?  (Read 631 times)
Offline r6502Topic starter
« on: July 24, 2023, 12:20:59 pm »
Hello all,
we have to evaluate 4 load cells at the same time, and found the HX711 chip, that has an internal reference, regulator for the load cell supply and can evaluate 2 load cells. Very interesting chip.
Has someone experience with this chip, and where to buy the chip itself - i can only find breakout boards with this chip, not the chip.
Any info is welcome.
Thanks  Guido
Science can amuse and fascinate us all, but it is engineering that changes the world - - Isaac Asimov
Online Kean
    • Kean Electronics
Re: HX711 scale amplifier where to buy / experience?
« Reply #1 on: July 24, 2023, 01:38:14 pm »
I've worked with the HX711 in the past, but I found it a bit annoying to work with.  If you don't get the read timing just right you can get spurious readings.
Apart from breakout PCBs and modules (i.e. Sparkfun, M5Stack - both available on Digikey) you can source the ICs from many random sellers on AliExpress.
If you are going to want a commercial relationship, then contact Avia Semiconductor directly. http://en.aviaic.com/detail/730856.html
There is a good Arduino library for the HX711 and lots of helpful info at https://github.com/bogde/HX711/
Personally, I switched to the Texas Instruments ADS1232 (back in 2015) and it has been a great solution for my wildlife monitoring systems.  I use this mostly for dynamic weighing of penguins, but also some other projects.
The following users thanked this post: doktor pyta, mycroft
