Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Metrology
Solar water Temperature logging data
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Solar water Temperature logging data (Read 1476 times)
cleanworkbench
Regular Contributor
Country:
on:
March 26, 2019, 09:12:33 am »
Am i in the right dept for asking about temp data logging. I,m looking into collecting data time vs temp for a diy passive solar system i want to build and want to use my laptop with either open source or maybe rasp pi or some very cheap method. Any suggestions please.
Logged
maat
Regular Contributor
Country:
Re: Solar water Temperature logging data
Reply #1 on:
March 26, 2019, 08:46:15 pm »
I can recommend Tinkerforge (
https://www.tinkerforge.com
). I am not affiliated, but I use them for logging at home and in the labs at university. They are open source (both software and hardware) and have great support for different programming languages. Tinkerforge offers both a Thermocouple bicklet (
https://www.tinkerforge.com/en/doc/Hardware/Bricklets/Thermocouple_V2.html#thermocouple-v2-bricklet
) and a PTC bricklet (
https://www.tinkerforge.com/en/doc/Hardware/Bricklets/PTC_V2.html
Logged
cleanworkbench
Regular Contributor
Country:
Reply #2 on:
March 27, 2019, 11:38:26 pm »
Thanks Maat . You,ll have to excuse here as your talking to an oldie !!!
Tinkerforge looks good . Do i need a bricklet for every thermo couple channel and is it all through RS232. Going to have to get a RS232 card for the mother board here .
Any idea of costs please.
Logged
beanflying
Super Contributor
Country:
Toys so very many Toys.
Reply #3 on:
March 27, 2019, 11:53:51 pm »
There is a huge number of hardware options out there what you should maybe look at is does the available software do what you want 'easily'. Software for this sort of project is the time killer.
If you feel like a software challenge then rolling your own with an Ardiuno or Pi base with some extra blocks of hardware is fairly straight forward. An Arduino or ESP (WiFi) based board with a couple of Maxim K type
eBay auction: #282551916471
or RTD
eBay auction: #283280456965
would be one path to go down.
This neat WiFi 4 channel one was on Crowd supply recently and is now in production phase
https://www.crowdsupply.com/capable-robot-components/sensetemp
Personally for a one off I would look for an off the shelf solution with the best software already available unless you have the time/skills to write code.
Logged
maat
Regular Contributor
Country:
Reply #4 on:
March 28, 2019, 12:56:25 am »
@cleanworkbench: The Tinkerforge system requires one Masterbrick (
https://www.tinkerforge.com/en/doc/Hardware/Bricks/Master_Brick.html
), which controls up to 4 so called bricklets. Up to 4 Master bricks can be stacked onto each other. The whole stack can communicate through USB and there are several extensions available (
https://www.tinkerforge.com/en/doc/Hardware/Master_Extensions/Master_Extensions.html
). We usually run those stacks through Ethernet + PoE, because it removes the necessity to have a separate power cable, but RS485 is also possible.
Tinkerforge is not the cheapest system to buy into, but it is very polished and has excellent support, both hardware and software wise. The API pretty much hides any low level hardware stuff, which is also one of the reason we have it in the labs, to keep the barier to entry low for new students.
That SenseTemp project also looks very nice, but it is much closer to the hardware.
Logged
cleanworkbench
Regular Contributor
Country:
Reply #5 on:
March 28, 2019, 08:50:31 am »
Thanks guys for the info . This is all new territory for me i did not even realize stuff like this existed . I,m going to have to study this info and think about whats best , very interesting Thanks.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Metrology
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
