Author Topic: How to maintain a bank of standard cells  (Read 2239 times)
Offline zhtoorTopic starter
  • Country: pk
« on: July 12, 2017, 07:20:10 pm »
Hello everybody,
what would be the proper way to maintain a set of saturated standard cells ?
1. oil bath design
2. temperature range
3. humidity issues
4. automatic comparison / back-to-back nulling system
etc...
regards.
Offline Conrad Hoffman
    • The Messy Basement
Re: How to maintain a bank of standard cells
« Reply #1 on: July 12, 2017, 07:59:37 pm »
Really broad question. IMHO, the best way to maintain them is not to disturb them. Temperature control can be air or oil- double air ovens have been used, like Julie Research did with theirs. It should be battery backed with a substantial capacity battery because recovery time is long. Most degradation probably comes from frequent over enthusiastic comparisons. Depending on what you need to do, comparisons once a month or even twice a year might be sufficient.
The following users thanked this post: zhtoor
Offline edpalmer42
« Reply #2 on: July 12, 2017, 08:00:11 pm »
Maybe start with this:
NBS Monograph 84
Standard Cells:  Their Construction, Maintenance, and Characteristics
https://archive.org/details/standardcellsthe84hame_0
AFAIK, most of the 'ordinary' commercial Standard Cells (Eppley, Guildline, etc.) use air baths rather than oil.
Ed
Offline ManateeMafia
« Reply #3 on: July 12, 2017, 08:28:07 pm »
Question #4 start with this... http://www.dataproof.com/NBS430.PDF
You will need a meter that can measure down in the nanovolt ranges. You would also need a switching system similar to the Data Proof scanners. It can be built by using some low thermal emf relays.
The NBS430 doc includes examples and they were handy when I started writing my software. Making it automated is nice but could end up being costly unless you plan on adding several cells.
  • Country: pk
« Reply #4 on: July 12, 2017, 11:57:50 pm »
thank you, that is what i was looking for.
I plan to have 9 cells in the system (maybe more if i can acquire more).
regards.
  • Country: pk
« Reply #5 on: July 13, 2017, 12:03:25 am »
thanks sir,
i have a 24VDC / 20AH NiCd battery with an associated charger for backup purposes.
sometimes we have electricity outages of 5+ hours.
regards.
« Last Edit: July 13, 2017, 12:12:59 am by zhtoor »
