Author Topic: Standard Reference Labs Trancells: any information available?  (Read 4489 times)
Offline tggzzzTopic starter
« on: February 12, 2017, 09:58:10 am »
I've just taken a punt and bought a couple of 10V sources for small change - but I haven't fetched them yet.
The only info I have is that one is a main-powered "Standard Reference Labs VTS-5/10-A-2", and the "Standard Reference Labs TC01" is powered from 28V.
Is there is any information available, and/or any hints and tips as to how to use/abuse/recondition them?
Thanks
Offline Vgkid
Re: Standard Reference Labs Trancells: any information available?
« Reply #1 on: February 12, 2017, 10:45:18 am »
Unfortunately no model info can be found. I tried looking in detail a few years ago, and a quick search just now. Look into Kenneth Koep, he did some work with nist/nbs.
I was buying 10v supply(not a precision one), but it ended up getting stolen from the dealer.
« Reply #2 on: February 12, 2017, 11:27:41 am »
Drat.
I'd seen the name "Koep" in conjunction with Trancell, but haven't worked out the actual connection.
Drat again :(
Offline Vgkid
« Reply #3 on: February 13, 2017, 07:03:42 am »
The following users thanked this post: tggzzz
Offline manganin
« Reply #4 on: February 13, 2017, 01:34:19 pm »
As far as I know all the Koep / SRL units were built around a selected zener (~1N829) and the well known circuit.
They also sold the diodes individually under their own brand and part numbers. If money was not an issue, TC less than 1 ppm/C, stability 5 ppm/year and rms noise level 0,08 ppm guaranteed.
« Reply #5 on: February 13, 2017, 01:59:28 pm »
This is the closest to any koep manual.
http://www.ko4bb.com/getsimple/index.php?id=download&file=06_Misc_Test_Equipment/Standard_Reference_Labs_VTS4007_Operation_Manual.pdf
Why didn't I find that? Sigh, sometimes I irritate myself.
When you get it, take a lot of pictures.
Other than geek porn, in order to show what?
The auction pictures are attached.
Offline ManateeMafia
« Reply #6 on: February 13, 2017, 02:40:43 pm »
I have a triple output Koep reference. I got that original document linked above and uploaded it a while ago.
Inside my  unit, all references are potted and have wires that come out to the front panel. Not a lot to see. They are not isolated as they share the same common.
Behind the faceplate of the inner shielded enclosure was dry rotted foam. It is certainly worth a look to make sure some hidden mess isn't floating around inside the box.
Offline Kilrah
« Reply #7 on: February 13, 2017, 02:42:53 pm »
Pretty sure he was referring to the innards/construction.
« Reply #8 on: February 13, 2017, 03:10:15 pm »
Very decent of you; thanks.
Yes.
Indeed. Maybe there is an old battery inside, hopefully intact.
