So I am trying to learn how to stabilize the measurement at the low end of the DMM - and as a source I am using the temperature stabilized standard cell (in an unheated calorimeter).
Am getting decent readings, but can't figure out a certain "hash" of 1uV I am getting on the readings. In the chart below, the axis are as follows:
X axis is hours of the day (so roughly 31 hour span of readings)
Y axis Blue is in PPM units for the voltage (re a ref-level of 1.0176748 volts)
Y axis orange is Lab delta T in degrees Celsius (re a ref temp of 25C)
The HP34401A DMM is set to 100PLC, maximum resolution (@1V range), >10G and AutoZero on. Logging is on a RPi3.
The question I have is how do I deduce whether the has comes from the DMM or the cell (or some thermal EMF along the way)?
Notes:
1. I suspect the hash comes from the DMM so I tried shorting the DMM input. But I then didn't get the hash - so either it is an effect that happens at a full scale reading, or it is the standard cell's doing (but how could that be? does electrochemistry have effects that have 1uV "jumps"?).
2. Cables are copper and I put some lagging on the bananas (gold plated tellurium copper - assumedly...).
3. It should be possible to stabilize the reading further by heating the calorimeter so that the temperature regulation loop stabilizes completely.
