Yes they use a few transformers, and separate the voltage from the current measurement, by having one transformer, normally a variac driving a regular 1:2 isolation transformer, to get the 230V range capability, with this connected to the input line and neutral, allowing you to drive the line voltage coils, or the internal power supply for electronic ones. Then you have a separate variac, driving another transformer, this one being120VAC to around 12VAC, but with a secondary capable of providing 100A of current. This then is connected between the line input and the line output, with an ammeter connected in series as well. Line voltage and line current are then set to the correct values, and they run the unit with a set current and voltage for a few hours, checking for the analogue units that the faraday disk does the correct number of turns per unit, or the digital one shows the correct number of pulses.
