I picked this up at a local ham flea market.
It's Rubicon 2732 Precision Potentiometer. I'm not sure exactly what it does, but I'd like to get it going. I think it's a sort of Wheatstone bridge and/or accurate voltmeter. I think the design dates from the late 1940s, but parts inside say 1963.
On the left is a mirror galvanometer. It was all messed up when I got it (the beam missed the ground-glass screen completely) but I adjusted it and it seems OK now.
On the right is a giant graduated slidewire pot, two pairs of EMF terminals and a switch to choose between them, a small unmarked knob that turns thru about 30 degrees, a big clickly rotary switch marked "MILLIVOLTS" that goes from 0 to 160 in steps of 10, a switch that chooses 0.1 vs. 1.0, and two buttons "EMF" and "SC".
Inside is what appears to be a Weston cell (reads 1.017 volts, which seems a little low, or my 5.5 digit DMM is off).
The instructions:
They say it runs on a #6 dry cell and two #2 dry cells.
A #6 appears to be a giant 1.5 volt carbon-zinc cell. I hooked up an alkaline D cell - something in there is drawing 15 mA.
I can't tell what a #2 was, but it appears to only run the 3v light bulb in the mirror galvanometer, so I connected 2 C cells in series - it seems happy with that (I get a nice spot and hairline).
So it says to do the "Standardization" by tapping the SC button and adjusting the "standardizing rheostat" (whichever that is) "until galvanometer stays on scale when button is tapped".
When I tap the SC button the beam goes way off to the right. No adjustments seem to change that.
So I'm stuck. Which one is the "standardizing rheostat", and what is going on here?
Underside of right side:
The Weston cell:
View toward underside of galvanometer:
