« on: February 12, 2023, 05:06:56 pm »
This is a germ of an idea. Lots of the prep work is already done.
PCB is in the process of being fabricated.
I will be using 1G resistors that I have sorted into pairs that are within ~200 ppm of 2G.
This first attempt will not be guarded. It will have a triax jack on low side for minimizing leakage on the low side.
I bough a 100M, 10M per step Hamon transfer standard to see how it works.
I do not care about leakage on the high side. The PCB creepage will be minimized with 1mm wide slots.
« Last Edit: February 12, 2023, 05:09:32 pm by VintageNut »
Logged
working instruments :Keithley 260,261,2750,7708, 2000 (calibrated), 2015, 236, 237, 238, 147, 220, Rigol DG1032 PAR Model 128 Lock-In amplifier, Fluke 332A, Gen Res 4107 KVD, 4107D KVD, Fluke 731B X2 (calibrated), Fluke 5450A (calibrated)
