Ok, looking closer at alm’s example, it looks like v-hz is shown as a unit, not a math operand.
If that is the case, then besides the obvious ultimate limit of 750VAC, the formula
≤8 × 10e7V·Hz.
means a limit of 8VAC or less at 10Mhz, or 80VAC at 1Mhz, 4VAC at 20Mhz, 2VAC at 40Mhz, etc.
Could someone confirm?
Thanks,
Jeff
